Question about Garmin 12CX GPS Receiver
Nuvi 200 power plug loose - only if cord pushed to right will it accept power from cord. Want to open unit to fix.
  • Garmin Master
  • 2,130 Answers
Please see this link for more information on this problem. Please do not attempt to take your unit apart and you might cause additional damage to the unit.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Sep 14, 2009
A family member gave my son a garmin nuvi 260 the cord was broken so i got another but when its plugged in to the car only get a computer connect pic and where is only when its unplugged can we get maps...
Sometimes this problem is caused by the power cord not being pushed fully into the back of the satnav even though it feels like it is. Pushing it in further usually solves the problem. If the power cord you're using is not a garmin this could also cause the problem.
Jun 24, 2011 | Garmin nuvi 260W GPS Receiver
The power and mini USB connector on my Garmin Nuvi 200 has gotten loose and it will not hold the connection through the power cord without being held by hand. Is there a repair for this?
USB connectors are too fragile for the constant in-out service they get. But I have solved the "loose USB" problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Dec 29, 2010 | Garmin nuvi 200W GPS Receiver
Shuts down when driving, looses power, and goes to battery
If your Nuvi's battery is low, and the plug becomes loose, then that may be your problem. If your Nuvi is acting up due to a firmware / system software glitch (common common common), then I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites (if your computer will still recognize it or if you have a memory chip you can pop into a card reader).
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Apr 11, 2010 | Garmin nuvi 200W GPS Receiver
USB connector in the back is loose and will not
If the connector in the back is loose, its not a Nuvi 350. A nuvi 350 has the connector on the side. In any event, please see this link:
- Jim
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 200 keeps shutting down
You may need a new power cord, I have the nuvi 250w and the cord is getting bad after a year. The battery will only run it for a short time.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
Two year old #200 unit. Plug seems to come loose
yikes! unfortunatly it sounds like you will have to send that back into garmin for repairs. for loose parts inside they are the only people who are authorized to repair it. Unless you know someone who is good repairing electronics
garmins website will give you a flat rate repair on what it costs to fix it.
Aug 14, 2009 | Garmin nuvi 200W GPS Receiver
The jack in the back of my nuvi 200 pushes in when
actually that component is soldered on the internal board and now its got moved from its position and the soldering has vcome loose.just get that component again soldered on the board to make it properly charge.
Mar 02, 2009 | GPS
Id the Garmin Nuvi 200 supposed to function when plugged in?
Are you using the factory supplied Power cord or a standard Sony-type plug?
Mar 01, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 12CX GPS Receiver Logo
703 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
