Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Model 22 Icemaker is not making ice - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
    Sergeant:
  • 222 Answers
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Posted on Sep 12, 2009
GE Icemaker
Switch sounds like its sticking. Micro switch needs to be replaced
Jul 25, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
No water in ice maker
Hi Binh. Welcome to FixYa. I am Kelly
First I want you to look at the 2nd link below and check item 22 for ICE buildup. (Use your finger) If there is ice buildup in that area use a hair dryer and melt the ice there until it is completely gone.
A quick way to find out if the icemaker is in an ice harvest cycle is to touch the bottom of the icemaker. It it is warm or hot to the touch then it is in the harvest mode probably due to ice build up.
Here is a link to test your icemaker and water valve assy.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link is step by step
"How to" information. When it has you jumpering the terminals to start the troubleshooting process it may take longer than the 2 - 3 seconds it states in the procedures.
Parts for you icemaker can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150689&diagram_id=930039#d930039
If you need further assistance then just respond here and we can go on from there.
Thanks for using FixYa.
Kelly
Apr 19, 2010 | Whirlpool ED5FHEXMQ Side by Side...
I have an icemaker in my refrigerator, but it is not making any ice. the water is on, so what could be the problem?
icemaker has to reach 10F (22 degrees below freezing) to start harvest cycle. a thermostat closes a circuit to a motor and heater to start the process. if there really is no problem with the water supply, problably icemaker is bad. also check fill tube freeze up.
Jan 03, 2010 | Whirlpool Refrigerators
I have a Jenn-Air refer model #JRTD226 with a built in icemaker. The icemaker makes ice fine except a small drip of water continually drops from an area just behind the front module and forms a large...
sounds like you have a crack in the mold of the icemaker. they do not make replacement parts for these icemakers. you will have to replace the whole icemaker. hope this helps.
Oct 21, 2009 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
298 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
