Question about Panasonic Audio Players & Recorders
The unit a Technics sa gx290 is a surround sound needing woofer h
The unit, a Technics sa gx290 is a surround sound receiver with five speakers and a large woofer. My question is how do I hook up the woofer. There no special outlets, just the black and reds for five speakers. Any help would be appreciated.
Raveler
  • 36 Answers
SOURCE: sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Posted on Jan 01, 2008
Drummernick
  • 440 Answers
SOURCE: Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
Posted on Feb 04, 2008
tech240
  • 169 Answers
SOURCE: probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Posted on Apr 25, 2008
SOURCE: How to set tuner presets in Technics SA-GX550 receiver
The user manual is available free at:
http://support.panasonic.co.nz/docstore/SAGX550%20Book.pdf
Posted on Jun 26, 2008
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
What settings do I need to get all 5 speakers to have sound?
Assuming all five speakers are correctly installed, you would select surround mode on your remote
Feb 18, 2013 | Technics SA-DX750 Receiver
How do i hook up my optimus sub that has pos&neg L-R in & pos&neg L-R out
Connect the Technics front Left and Right speaker out to the Optimus Left / Right IN. And what ever speakers you were connecting to the Technics front Left and Right connect it to the Optmus Left / Right Out. This is called a loop through connection. Just make sure the Amplifier red is connected to the sub woofer red and the Amplifier black is connected to sub woofer black - i.e No mixup on the colors.
Apr 29, 2011 | Technics SA-DX930 Receiver
How do I stop the hum coming from my surround sound speakers
You have a ground loop, most probably. Try grounding your receiver by running a copper wire to the screw on the electrical outlet.
May 02, 2010 | Technics SA-AX540 Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Apr 06, 2009 | Technics SA-AX720 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Can't hear any sound from the large left or right speakers
is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Jan 26, 2008 | Technics SA-AX540 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
174 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
