Question about Ricoh Office Equipment & Supplies
Ricoh FT5535 paper misfeed
I have a Ricoh FT5535 copier that keeps misfeeding whenever I attempt to make a copy. Paper tray selection makes no difference since they all eventually must make its way into the same feed area. Can someone please tell me how to access the roller area so that I can inspect it. I've tried taking apart the bypass tray to access the rollers but no success. Any help would be much appreciated.
    Guru:
  • 389 Answers
I know your Ricoh. Your problem simple. However me it is difficult you tell in internet.
Let's on order. I Sergey, My experience of the work 18 years. Rico although and good копир, however moody. Here, it is difficult without skilled help. I have understood so that beside you stick the paper in enterring трэке. And with hands direct move and with pallet. Then listen. I shall enumerate причичины, but in afterwards check.
1. Vysoh giving roller.
2. The Substrate, which is found under rubber roller or is damaged or disappeared.
3. Exists the damage to axis of the presenting the paper and she on adjoins to paper exactly 4 Simply there is hindrance to passing of the paper 5 Sensors of the entering the paper or is littered or small flag sensor came out of jack and his(its) has wedged 6 Nakonc, most probably, this only in device Ricoh - on axis, which provides in motion feeder, seizes the paper, on which roller, on the part of opposite front behind there is bushing of the joining, she provides in motion roller joinings and stretches the paper. This bushing of the joining устроета thereby that she abrades or is polluted by dust. It is Necessary to remove the back cover, get before this bushings to see her(it). Otkrfti front lid and put(deliver) the stub on sensor to make lid and look, what operates the mechanism of the drive in moving the axis on which is located roller of the presenting and tracktor of the papers. Attentively define in what time stops the paper. Advisable give the paper with hands without pallet. If you find that gross does not revolve, but щелчQк there is, you necessary to analyse the bushing which on axis and wash the alcohol and define her wear-out, otherwise her(its) zameniti. my address goodgold@inbox ru Sergey. Write
Posted on Sep 12, 2009
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
I have a ricoh ft5535 copier. When I click copy the display panel reads, "misfeed remains inside" and the area "A" light comes on. There is no paper in the machine anywhere.
This alert can result from the smallest portion of a paper misfeed. Open all doors and look into each roller corner for a piece of paper that may have been jarred into a corner.
Dec 31, 2010 | Office Equipment & Supplies
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
RiCoh 1075 MisFeeding...
The problem you are having is that developer has fallen down into that area good luck once this has happened the box must be taken apart and blown out...  good luck
Apr 22, 2009 | Ricoh Aficio 450 Copier
151 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
