Question about Lexmark X2330 Printer
I don't know where to put the paper
I don't know where to install the paper into the printer
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
I bought the machine used and don't know how to install the paper or use the machine. Can I order an instruction book?
I put the manual up on my server. Get it quick, I'm taking it down in 24-hours.
http://www.itrsva.com/000-SCX4521M.pdf
Jul 19, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
I m unable to download the proper printer driver for windows xp 32 bit i don't know even how to use this printer where to put paper, & how to change cartridge, what model of cartridge etc
Please check the content of your printer. You should have there the manual , cables, and CD driver. If you don't have, please get down loaded your printer driver at manufacturer website. Check the model and type then search download bar.
May 06, 2011 | Office Equipment & Supplies
I don't know how to install the paper
Place the paper in the tray on the bottom of the printer. When a printer says "Install the paper" It doesn't really mean to install per say.. just means to put paper into the tray.
Mar 29, 2011 | Computers & Internet
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
I cann;t Copy or print in paper 81/2 x 14 in the IR 3100 canon
Just guessing.... Not knowing the model or Make of the copier. You Probably have to change the papersize on the drawer that you are putting the larger paper into to equal 8.5x14: usually by a dial or the position of the fences (side and rear paper guides inside of the tray)....
Mar 29, 2009 | Office Equipment & Supplies
Lexmark X2330 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
