Question about E-Machines eMachines Desktop PC
CPU Problems with the help from answers on here, I have decided that my cpu is finally gone. tested monitor with another computer = monitor works, tested computer with other monitor = computer turns on but still can't boot bios. tried with both old and new graphics card. is there anything else I should try before I go and buy a new computer? also if I do need to buy another computer how do I get all my files and pics and stuff from old comp?
  • 1,606 Answers
What can also give the same symptoms as a doa cpu is bad ram. About the only difference is that you usually get a post code with a cpu problem and absolutley nothing with ram.
About the only way to check a cpu is to swap it out. They are not that expensive compared to a new pc unless you want an excuse to upgrade ;-]
Ram is checked by swapping it out or just removing and checking one stick at a time. Sometimes they just need to be reseated and away it goes.
Also check the power supply. If it has overheated or dired etc nothing will work.
Once you have checked out those three you will know if it is worth fixing or junking.
Posted on Sep 11, 2009
Testimonial: "ok Im gonna head straight to Best Buy and get those 2 items. trying not to buy new comp but if I do have to how do I get my stuff saved on other comp"
Likely causes: RAM, CPU or motherboard or PSU.
Possibility that Motherboard not earthing properly.
Unlikely to be CPU. More likely faulty ram or board.
Try resetting the CMOS settings, by moving the CMOS jumper to the opposite position for a few seconds (powered off) and back again. This often brings things back to life. ( can also take out battery overnight)
Try: Remove all extra cards, even video card from Motherboard. Put in only 1 RAM chip, firmly seated. Try also with other RAM in other slot(s). Connect speaker to Speaker port on board if nott already connected. Power up. listen for diagnostic 'POST' beeps.
If its a P4 PC make sure the power supply 4 way 12v plug is in near the CPU area. this is a common fault.
If computer beeps it is video card or RAM. If no beeps, motherboard is suspect. Remove board entirely from PC, mount on cardboard on the floor, put in the powersupply cable 20/24pin connector and (12v P4), plug in monitor, keyboard and mouse.
Power up. if it works normally, there is an earthing problem in the case; check all the mounting posts are in the correct place.
If board still dead, time to get a replacement board. Look for one that's the same type as your CPU and current RAM,for a straightforward swap; idelaly the same type if you want your old disk to work properly first time without mods. search on ebay, there are often boards about. That is unless you're going for an upgrade; a cheap one is an AMD M2+ board , CPU and newer RAM. Buy a cheapo CPU to start and change it when you need more power. Board £35 pds sterling, CPU £20, RAM £20 ish..
If you have a new board, then the previous harddrive will not boot with new hardware- you will get the familair blue screen of death most likely. Buy a £10 IDE or SAT to USB connector cable from ebay and remove your drive, connect it to another PC, ior laptop viaUSB, and copy away all your documents, settings and user files or better make a disk image via Acronis or Powerquest Drive image from which you can extract your important stuff later.
if you cant do this beg borrow another harddrive and use this to set up your new Pc. Then add your old drive to the PC. when it has windows and extract the files that way.
Dont bother with programs; they can be reinstalled from original sources, your data and settings are important.
Good luck.
then
Posted on Sep 12, 2009
Problem with AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+ 3.5MB HD8450WCJ3BGH
Your motherboard might finally need replacement. If the temperature sensors aren't working and the motherboard isn't controlling the CPU fan, that shows you might have some problems with it. Did you try going into BIOS Setup and checking your settings? Check the cooling settings. Many motherboards have aggressive CPU temp monitoring as well, so if the CPU gets hot, the PC will shut down.
Jan 09, 2014 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
External monitor inop. Just stopped working.
just to chk out if thats a hardware issue with the monitor ... power on the monitor and disconnect the data cable which is connecting the monitor and the CPU ... disconnected the blue end of the cable which is connected to the CPU and see if u see a test signal on the monitor if yes than its a issue with the CPU and if u do not see the signal that means ur monitor is gone bad
Jan 27, 2011 | Dell Computers & Internet
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
No display...orange led on monitor.....
Thank you for using fixya, my name is Carlo.
You have two possible problems.
1. Monitor
2. Computer
Here's what you can do:
1. Unplug the cord which connects the monitor and the chassis or the CPU of your computer. It's the blue one.
2. Let the monitor to turn on even if it's not connected to the chassis or the CPU of your computer. If you can see their a box which is moving around the screen, then, your monitor is working fine. If none, then you should buy a new monitor.
3. If your monitor is working fine because you can see something on the screen after unplugging it from the CPU, then it's the CPU that has a problem on it.
If the monitor passes the test, then, the CPU needs some troubleshooting. Opening a chassis is not that hard but it still need some troubleshooting hands for you to do that. If you are not that techy, I suggest you get a technician to do that or any person who can do the troubleshooting.
Here's the troubleshooting that should be done.
1. Unplug the CPU the drain the power by pressing and holding the power button for 5-10 seconds.
2. Open the chassis. Then re seat the memory stick. Check if it works by turning it on, you have to connect the monitor while checking it.
3. If no go. Unplug, do the same with the hard drive, but most of the time, if the Led is orange, it's the memory that is not working fine.
Hope this helps.
For any questions, leave a message her. But if it helps, please rate and leave a comment and suggestion on how I am doing or on how I can improve my service.
Thank you for using fixya - your best online technical support site.
CARLO
var geo_Partner = 'cca8460f-a562-4792-a693-6fa0e7fcde78'; var geo_isCG = true;
Sep 27, 2010 | Computers & Internet
Motherboard power
hey, without seeing it its quite hard, if the cpu fan aint running you have either not connected the cpu fan cable up, or connected it to the wrong place,
are you sure you fitted the cpu the correct way round when you removed it,
and depending on the processor in the computer make sure you aint damaged any of the pins etc on the cpu.
if you can supply some pictures or something can probably help you better
May 28, 2010 | E-Machines eMachines Desktop PC
Soon as ssoon as i turn on the computer the monitor flashes the the logon screen; two seconds later the display is gone. The monitor indicates that it is still on but no picture. I turn the monitor off...
Here the monitor does not have any problem.Initially test monitor by removing the monitor cable from the cpu.
you can see small boxes moving in the screen this ensures your monitor is ok
Here he problem is with Ram in the cpu .Just remove the ram and clean the ram slot and ram and then fix it tt will work fine
May 21, 2010 | Computers & Internet
My monitor displays "No Signal Detected" minutes after left unused, but when plugged to another cpu it works well. How do i solve this,please ? Geoffrey
Hi Geoffrey,
The Issue is that the Serial Slot at the back of the CPU Tower has gone bad,you need to change the Serial Slot in your CPU and then Check it
Regards,
Ayyasam
Apr 03, 2010 | BenQ FP71E 17" LCD Monitor
LCD monitor stopped working on my CPU but works on my Brother's
Definitely some electrolytic capacitors are blown inside the monitor in power supply module. Open it and observe any of them rounded on top, replace with proper ones.
You see, controller operations with VGA and DVI inputs takes different current from the supply, that's why it may take different time until PWM chip in the power supply will decide it is time to shut down before getting smoked.
Replace capacitors.
Sep 06, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor Blinking
HI SrFixer -
Since you were able to attach another monitor to the computer and it worked, that would indicate that the problem is not a computer problem but a problem with either the monitor or the monitor cable (data). Try another monitor cable on the monitor that didn't work and see if that works. If it still does not work, then I am afraid that your monitor has gone bad and needs replacing.
Hope that helps
Michael
Nov 28, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
131 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
