Question about Dell Dimension 5100 (D51L1) PC Desktop
Just come back from a 2 week holiday and my dell dimension 5100 was off but i usually have it on 24/7. having returned from holiday , when i press the power button nothing happens but the yellow l.e.d light on the motherboard is on ... can anyone tell me my problem?
    President:
  • 1,179 Answers
This model has had a very high failure rate. The amber led on front is on to show an error. This can be 1 of 3 things. 1. The power supply has went bad. 2. The motherboard is bad. or 3. The front control panel is bad. Since Dell used proprietary parts on this model you would need to contact them for replacement. www.dell.com will have the contact info. Hope this helps.
Posted on Sep 11, 2009
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Need to purchase recovery disk for pc desktop DELL DIMENSION 4550
You can do it two ways:
1) call Dell and order a recovery CD--their contact info is on dell.com
or
2) use a regular Windows CD and install the system using the product number affixed to the case. Then go to Dell at support.dell.com to download the needed drivers.
Oct 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
How do I return our Dimension 5100 Dell Desktop back to it's original state? Lost the recovery CD.
Have you tried restoring your operating system to a previous restore point?
To do this click on start- all programs - accessories - system tools - system restore. Then choose a date from the calendar which corresponds to a time before you began to experience problems on your PC. Follow the on-screen instructions to restore your PC to its original state.
Note that a system restore will remove any programs which were installed AFTER the selected restore point date.
Hope this helps.
Regards,
Graemevm
Apr 19, 2009 | Dell Dimension 3100 PC Desktop
Dell Minitors has lost power
small cable to button/control lights may be disconnected
Sep 18, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 motherboard
I would try asking dell.go to www.dell.com lala linda
May 18, 2008 | Intel D845GVSR Motherboard
Power supply ?
I'd recommend purchasing a new power supply.
Your Dell Dimension 5100 comes stock with a 305W power supply. This is a bare-minimum wattage that will only handle what they ship on the system & not much more. You're better off upgrading the power supply with a compatible after-market model.
You can go to a PC parts store in your area and take your chances...but they're usually more expensive then Internet sources (they've got to pay for their brick-n-mortar store overhead).
Here's a link for a very inexpensive replacement 400W power supply for your Dell Dimension 5100:
http://www.affordablesurplus.com/dell-5100-5150-power-supply.asp
This particular site offers $8 Flat-rate shipping & a 1 year warranty. Your power supply is only $49.99 - you might be able to find it cheaper elsewhere, but that's the best I could find with a quick Google search.
If my answer helped you, please provide feedback :-)
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. bear350cid@yahoo.com Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 cd/dvd drive
Hi!
There should be a tiny hole on the faceplate of the CD drive. If you straighten out a paperclip and insert it into this hole and press in, it should allow the CD to be manually ejected. After doing this, press the eject button and see if that makes the CD drawer go in and out.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating.
Thanks you, and have a super day!
Ron-
Nov 12, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
192 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
