Question about Kenmore Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the leak??
  • Anonymous Mar 27, 2014
    Leaking water into the refrigerator
  • 93 Answers
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
What would cause my Kenmore Coldspot ice dispenser to freeze up where the water enters from the tubing into the ice maker itself?
Small leak in the tubing. remove ice-maker, cut tubing about half an inch back and reconnect ensuring the tubing is completely on the ice-maker.
Jul 05, 2016 | Kenmore Refrigerators
Kenmore Coldspot model#106.53359300 the ice maker not making/dispencing any ice, help?
Make sure the metal lever on the ice maker is in the lower on position. Check that the water valve for the 1/4 inch supply line is attached to the fridge and to the valve . Screw that water valve all the way in and then all the way out.
Jun 06, 2016 | Kenmore Refrigerators
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
I have a kenmore coldspot fridge model # 106.73182302. It is only 7 years old and it is not keeping a cold enough tempature in either the freezer of fridge. The problem started with water leaking from...
my gsi 23 ice maker continues to flow water into the ice maker after the tray is full. It flows non-stop and floods the kitchen until I raise the arm that turns the unit off. I have no ice?
Sep 09, 2011 | Refrigerators
I have a Kenmore Coldspot Fridge. The icemaker is leaking in the fridge and running water all over the inside causing ice to form every where. I already replaced the water fill tube. I noticed after the...
Yes exactly that is the water inlet valve thats causing that its not fully closing yet its staying open a little and seeping water through it.
GENE
We have a 10 year old Kenmore Coldspot Refrigerator (it looks like model # 590 9990). It is leaking water from the freezer door. We turned off the ice maker to see if that would stop the leak but so far-...
look for all/any drain holes and blow out/syringe with clorine bleach ,then check door seals for any air leaks.water in fridge is mainly condensation from warm food/replacement air when you open door.
Jul 02, 2010 | Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Refrigerators Logo
757 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
