Soyo KT400L-2AA5 Dragon Lite Motherboard - Lost Bios?
I power the PC up, one short beep and then a longer beep. No dispaly. Monitor indicator lamp stays amber. Hard Disk and Floppy DIsk indicators lamps stay lit.
If the Bios is hosed, what is my next step?
Thanks
    Problem Solver:
  • 11 Answers
Kinda sounds like a short, have you made sure youre motherboard is screwed in with ground case screws? Ive done this one by mistake and got these same errors, also a fried board after a while. You also need ram in it as well before it will give a display, also if you have a second video car dinstalled you may have the monitor in the wrong video card slot, common mistake. If your bios is hosed then you will need to by a new board if you dont wanna solder a new bios chip to the board
Posted on Sep 11, 2009
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
Screen is black
If the notebook appears to boot up and the LED hard disk light flashes then :-
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 13, 2009 | Acer Aspire 5100 Notebook
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
Screen
I assume your computer boots up, the hard disk spins and the hard disk LED light flashes.
If so then you may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 11, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Aspire 6920 after power up, goes to black screen
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Acer Aspire 6920 Notebook PC
Blank display
Check out
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite M35X-S161 Notebook
Compaq V3424au that has a blank screen on startup with all lights
Check out
www.lcdparts.net
Jun 23, 2009 | Compaq Computers & Internet
Display problem
Check out
www.lcdparts.net
Jan 21, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
