My hp deskjet 5550 keeps printing at an angle or either the paper jams. help!
  • hssfmom Sep 11, 2009
    How do I clean it? Thanks!
  • hssfmom Sep 12, 2009
    Thank you. I will try this. :)
  • 615 Answers
You need to clean it eather the roller does not work and need to cleaqn it good do not use alchol it will hurt the plastics, or oyu have a paper jam on that side...
Posted on Sep 11, 2009
  • Norman Al-Anbar Sep 12, 2009
    Look in paper feeder slot with a small light and check the rollers and if you can see any white materials, use a small air can if you can...use a cotton swab dry and see if any dirts come out especially next to the rollers and the shaft that hold them.
    OPen the printer using the manual (seehttp://www.fixya.com/Search.aspx?ctgid=0... and again start cleaning the parts without using any thing that may hurt the rollers...Hope that help and fix the issue...
I have hp deskjet 5550 printer,when i was trying to print a document there is no print out, two lights are blinking
Hi, This could be Low-Ink or paper Jam. Try turning off The printer, Unplug from The Mains Electric, for 3-5 Minutes. Turn back On, if Lights Are Still There. Check The Ink-Levels. And Replace Cartridges, if necessary.
Mike.
Jun 02, 2011 | HP DeskJet 5550 InkJet Printer
Tip
I followed the steps outlined by nanicool to remove jammed paper from an...
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
I have an HP deskjet 5550. I had a paper jam earlier but cleared it. After reseting, warning light still comes on. Printer makes clicking noise when I first turn it back on.
First off how long have you owned the printer? There are several possibilities at this point. Possible paper still jammed or damage done to a part while clearing the jam. Once I have more information I can assist you further.
Thank you,
Lee
Feb 01, 2010 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
Hpdeskjet 5550 had paper jam on page 2 of 3 page document, now dead. Turned power off and on, took cartridge out and put back in, nothing working
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
180 people viewed this question
jasbo
jasbo
