Question about Motorola Mobility RAZR V3
Battery died on razr V3, took it to Tmobile and they checked it out and said that the charger wasnt working. bought a new charger. now i am charging it and it keeps beeping and the light on the phone background keeps going on and off. is this normal?
One day i as using my razr and it just died so i put in a new battery but still didnt work. so what do i do?
1st try your charger 2nd if that dont work connect your phone to the computer with a usb chord and the process should be finish in a hour
Apr 25, 2010 | Motorola Mobility RAZR V3
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
My razr v3 died yesterday. tried all night charging, still dead. no juice to turn on. bought 2 years ago, worth new battery?
Well... I would say no.. Not worth battery.. I had the same thing happen to me where my phone wouldn't charge and we bought a new battery for $50.00 and then we find out my phone is shot.. so I would strongly recommend getting a new phone..
Oct 09, 2009 | Motorola Mobility RAZR V3
Razor v3
take the phone to a mobile service center and have them unlock it for you
Sep 18, 2008 | Motorola Mobility RAZR V3
Motorola razor v3
ya try 2 change ur charger. or it got problem inside with ur charger circut. try getting external battery charger frm market. so thatur one battery can be carged and another u can use it
Jun 04, 2008 | Motorola Mobility RAZR V3
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
Feb 05, 2008 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
Razr v3
If your charger is not an orginal Motorola v3 then you have a problem. Make sure its original. You may want to check your battery capacity, if thats below 3v then you need to get it back to standard capacity.
Oct 12, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
