Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Red light came on tv , replaced lamp and still no picture
I had the lamp go out on my tv , i replaced the lamp and i restarted the tv , it made a sound as if a fan was going , then the noise stopped , the sound was on but no picture , then 2 minutes later the tv shut off and the red light status came on in the lamp section , is there something im not doing or did i get a faulty bulb ? Is there a reset process im suppose to go through when replacing the bulb ? Any help would be appreciated , thanks
  • 11 more comments
  • babyboyyouth Dec 10, 2007
    I unplugged it and plugged it in multiple times and i got the same thing , is there anything else it could be , the sound works and everything , i hear a sound like the fan is going and the fan stops , then after two minutes it shuts down and that red light comes on ,
    Would this cause the red light to keep coming on ? This may be a silly question but will the red light come on if it is not detecting the lamp ? thanks for the help
    Which one of these errors will indicate that the bulb is not secure or that it needs replaced ? Some tv tech just emailed me and said i may have pushed the ballast plug out the tv housing , i dont know what that is , and he said it may be a bad power assembly , does it sound like that to you ?
  • babyboyyouth Dec 11, 2007
    thanks , he called me last night at home and i pulled the back off the tv and put the lamp in , the plug totally came out when i pushed the lamp in , so i just have to get that part fixed , hopefully i can this weekend , i hope that is all that is wrong ,
    yes , i can do it from my digital camera tonight , it totally popped out when i put the lamp in , i had to have my fiance hold the lamp while i plugged in back in , he stated that if that dont fix there is an issue with the 5 or 12 volt or something , i did that error test you sent me and it came up as 12 ,
  • babyboyyouth Dec 13, 2007
    I got the connection on the tv working , but the lamp will not come on , im getting error 34 now , any idea what that might be , tech told me might be bad power supply or ballast plug bad , please let me know , thanks ,
  • babyboyyouth Dec 14, 2007
    I did the system reset on the tv , not sure if i do it before i get the error or after i get the error , and as far as the ballast i dont know how to check for voltage on it , im cluelest to it ,
    Tell me what you mean by making sure the ballast connectors are bent over , thanks ,
    ok , please let me know if you find one ,
  • hecibarra198 Dec 06, 2008
    I also have the same problem, no picture only sound. The red light came on, so i changed the light bulb and its still the same . Have anyone found a solution
  • Anonymous Dec 08, 2008
    i have the exact same problem. How can I fix that?.
  • Anonymous Jan 12, 2009
    replaced lamp on 12/22/08 problem is back!
  • mesk272829 Jan 31, 2009
    It sounds like I'm having the same problem> Did anyeone figure out what the problm was and how did they fix get it fixed.
    President:
  • 4,402 Answers
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Posted on Dec 10, 2007
  • 8 more comments
  • Cary Farah
    Cary Farah Dec 10, 2007
    you can unplug it a million times and it wont help you have to get at the plug and make sure it on firm.
  • Cary Farah
    Here's something that might also be useful. After you turn on
    the set, and get the regular red blinky lights, hold down the Device
    and Menu buttons together for about 5 seconds.
    The Power light will start to flash in a two digit sequence.
    For example, 3 flashes, then 7 flashes = 37.
    Here are the error codes, and the corresponding problem:
    12 = No error detected, check power supply.
    32 = Lamp Cover is open.
    33 = Air filter cover is open.
    34 = Lamp abnormality
    36 = Light Engine (DMD or Lamp Fan stopped)
    37 = Exhaust or Lamp Ballast Fan stopped
    38 = Lamp Temperature High
    39 = DMD Temperature High
    41 = Short is detected
    44 = DVI cable between FMT and Engine disconnected
  • Cary Farah
    Cary Farah Dec 11, 2007
    Afterreplacingthelampcartridge,whenyoupowerontheTV,themessage"Didyouchangethelamp?PressENTERforYes,pressCANCELforNo"willappear,pressENTERtoreset.
  • Cary Farah
    After replacing the lamp cartridge, when you power on the TV, the message "Did you change the lamp? PressENTERf or Yes , press CANCEL for No "will appear, press ENTER to reset.
  • Cary Farah
    some tv tech just emailed me and said i may have pushed the ballast plug out the tv housing <<<<
    that is what i have been trying to get you to make sure didnt happen in the previous messages.
  • Cary Farah
    That what i thought, is it possible to take a picture of that so i can show others email it ctf1800@yahoo.com
  • Cary Farah
    Cary Farah Dec 14, 2007
    The first thing to do is a system reset using the recessed button on the front panel.
    34 Lamp did not turn on
    The most common is of course the lamp.
    If the lamp is new and the ballast connections are not bent over, then the next probable part is the ballast.
    I check for voltages and signals going to the ballast and if they are there, the ballast is bad.
    Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver
    PCB if missing replace the Power PCB part # 930B921002 3.
  • Cary Farah
    not bent over, ill have to see if i can find a picture, i thought i saw one on one of the forums.
  • Cary Farah
    Cary Farah Dec 15, 2007
    ok, i search on error code 34
    found this to a simular problem you have
    The set has been in the repair shop... from what I understand, it was a
    bad IC9A20 chip (wherever that is). Replace that chip, reset to
    factory, center and align mirrors.
    that chip is the voltage regulator chip
    http://www.hdtvoice.com/voice/showthread...
  • Cary Farah
    Cary Farah Dec 17, 2007
    found this today:
    Probably bad capacitors. My 52525 has the same issue using component
    cables and tech said the capacitors on the formatter board has to be
    replaced. Part back ordered
    New Friend:
Throw it away and buy a sony
Posted on Aug 07, 2013
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
Picture has become darker and darker, but now there is no picture or sound a red flashing red light in the lower right hand corner.
Time to replace lamp in tv.
Existing lamp in tv is dead and tv needs new lamp to work again.
Lamp replacement procedure is easy and written in user manual of tv.
Oct 10, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
HITACHI ULTRAVISION DIGITAL TV.MODEL NO: SP60WS lamp light is red
The lamp should be replace to fix the no picture since the lamp light is red.
Download the user's guide and see pages # 69-72 for lamp replacement.
Jul 10, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
Flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
May 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
2,289 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
