Question about Zenith H25F36DT 25" TV
HAVE A 25' 1990 FLOOR MODEL ZENITH AND BOTH SPEAKERS WORK BUT THE VOLUME IS NOT LOUD PLEASE HELP
My 1990 Zenith floor model #SS2505TR flashes entirely red with white lines throughout, so much that I have to continually turn it off and on to get a picture. Solutions???
Posted on Jul 01, 2011
    Sergeant:
  • 269 Answers
Hi! have your unit check by a qualified technician. its either you have some leaky capacitor on the audio amplifier.
Posted on Sep 12, 2009
1960 (approx.) b & w floor model TV sound suddenly doesn't work.
check av card
check speaker
check any dry soldering in power supply & audio section
Mar 25, 2014 | Zenith Televison & Video
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
The volume doessnt go very high on my zenith 32' tube tv.
Hello daymakerserv,
Ok you are correct these sets have a master volume control accessible fro the remote control only. If you have the remote go to menu Audio settings and possibly advanced audio settings and you should see the master audio setting. Now you have to have the remote to do this. If you do not have the remote control, you will have to order them from the manufacture, they do have the model of remote that will work with these sets or they can provide an OEM remote that will allow you to access these functions. A universal remote may not work in gaining access to the master settings, so it is best to contact the manufacture and get either an exact replacement or one of the OEM models of remote.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 25, 2009 | Zenith B27A11Z 27" TV
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Re: Zenith dvd/vcr Combi Receiver ZHX-313 The middle speaker (C) has stopped producing any sound. The speaker itself is OK as I switched the speaker to another line and it works. The wire connection seems...
alanomarie, I had the same basic problem, was able to remedy it by selecting sound mode on my remote and pressing it till unit displayed 'prologic'. Hope this is of help.
kino536
Feb 19, 2009 | Zenith ZHX-313 System
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Dec 05, 2006 | Dell PART NUMBER KIT SPEAKER MM ACS45...
The volume is way to high even on the lowest setting
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
May 29, 2006 | GPX DV7500 System
Zenith H25F36DT 25" TV Logo
196 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
