Question about Dishwashers
Unclean dishes food particles left on glasses
    Sergeant:
  • 222 Answers
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Posted on Sep 12, 2009
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
There is food and grit stuck to my glasses. Where is this coming from? I am rinsing all the dishes before I put them in , so it must be in the dishwasher somewhere,
We used to have this problem with a Kenmore that had a built-in "garbage disposal"--it was a little blade that ground up larger food particles. Occasionally a cherry or olive pit would get inside and dull, chip or break the blade, and the symptom was food particles on the dishes. The solution was to replace the grinder.
Jul 26, 2011 | Frigidaire Professional Series 24 in....
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Oct 26, 2009 | Dishwashers
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
637 people viewed this question
Top Dishwashers Experts
Owen Barnes
