Installing External Hard Drive
Would like to give my old computer to my sick Brother, And would like to remove all my photos, files, etc. Purchased a WD My Book Essential Edition and I have tried to install it onto a Compaq 7478 model and it is not working.
Help Me
Evelyn
  • Anonymous Apr 09, 2008
    how can i receive the soft ware to install my external hard drive
My External Hard Disc isn't recognable on my PC. Than I'd rather download a program for its working.
Posted on Nov 08, 2008
  • 37 Answers
Are you sure that you have connected it to the USB 2.0 interface? In some systems, there are older versions of USB interfaces (having smaller data transfer rate-inappropriate for external HDD's) are also present.
Posted on Dec 11, 2007
My file settings for saving books in Calibre changed when I purchased a new computer. Can you restore to the original settings?
the area that has everything as you had it is the hard drive of the computer
new computer , new hard drive , nothing saved unless you saved it all to an external hard drive
It is very possible that if the hard drive in the old computer was still operational you could remove it and set it up as an external hard drive to recover all of the files and folders but if it was the reason for the failure , then it is all lost
Mar 19, 2017 | The Computers & Internet
External hard drive format recovery
Install ReclaiMe file recovery from www.reclaime.com in your computer connect the hard drive and you will see the disc the way it was before. With a few clicks you will recover your files.
Dec 22, 2014 | Western Digital Elements powered by WD 320...
Looks like my hard drive is full and it can not boot up. how can I get to the hard drive to delete pictures to have more space for window to load?
If the hard drive is not faulty and the computer won't boot up, then remove the hard drive from your computer and connect it an USB hard drive adapter. Connect the adapter and hard drive to a working computer's USB port, this computer will see this as an external storage device, you can then open the various folders and delete the photos or data files.
When you restore the hard drive back into your computer and when it boots up, your should do a Disk Cleanup then a Defrag. Disk Cleanup will remove old temporary files, old compressed files etc and free up disk space. Defrag will make fragmented files contiguous so the files can be accessed more efficiently. If you have not run these programs before, it will take a log time to complete.
Disk Cleanup and Defrag should be carried out once a month to maintain the hard disk.
Dec 20, 2010 | Computers & Internet
I need to transfer data from an old and sickly Dell Insiron 8100 to a new 2010 external hard drive....no conforming ports....pls advise what I need to purchase...cable?....for transfer ...and either...
The first thing I would do is pull the hard drive from the sick Inspiron. Now get yourself an IDE/SATA to USB adapter from a computer retailer or on Ebay, they cost about 20 bucks. Attach the HDD from the Inspiron to the adapter and attach the usb side of the cable to a good computer. The computer will now read this drive as an external and allow to access any and all files. Just make sure that before you remove the HDD from the Inspiron, you remove any passwords on the computer that might limit your access to files. Also on the good computer go to control panel > Folder Options. Click on the boxes to allow viewing of system files etc. just for a little while, during the files copy. Make a folder on your desktop and name it whatever you want. Now go through the HDD from the Inspiron and copy any and all files to that folder. When you have finished, attach your new external. Now just copy the files from the folder on the desktop to the new external drive and there you go. These adapters are the only true way to be able to pull this off. Good luck
Jan 28, 2010 | Dell (0K724) for Inspiron 8100 40 GB Hard...
I have just connected my External Desktop Drive and am now wondering what else I have to do to back up my old drive onto this one' I purchased this as I am running out of space and also need to backup my...
The simplest thing that I would advise you to do is this:
Locate the high-volume files and folders on your system, and group them together.
Put them all in a single folder and give the folder a Unique name e.g "My Valuable files".
Thereafter, copy this whole newly created folder onto the external drive and after doing this, defragment both your external drive and your System hard drive.
This should give you a whole lot of space and make your system to be very much faster.
Hope this helps.
Good luck.
Nov 22, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Jan 22, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Can't locate music & photos on an old hard drive
I created a program that finds music files.
It will probably be useful for you.
http://rapidshare.com/files/236925438/Find_My_Music_1.0.0.exe
Any questions contact me at QuackWare@gmail.com
Jan 14, 2009 | i-rocks External Hard Drive Enclosure -...
How do I get the files to the external hard drive?
First, u have to format your external harddrive, then just Copy and Past your desired forder from your computer to external hard drive.
Oct 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Hard drive/memory/speed
music files and photo files take up a lot of memory/space on a hard drive. If you are using your flash dirve (external drive) to upload songs, phots etc to a website (i.e. Facebook;MySpace etc.) you can upload them directly from the external drive rather than loading them to your computer. I suggest, that if you have a cd/dvd burner, burn all music and photo files to dic, if your external drive is for temporary storage. Once you have done this, remove all music and photo files (except any you may want to use as start up theme music, background use for desktop etc.) then, degragment your hard drive, C:\. Once the degragmentation is complete, close all programs and reboot your computer. NOTE: while you can operate the computer while a defragmentatioin is in progress, any use slows this process, as degragmentations (or defrag's) can take some time to complete (i.e. 1 hour or more depending on the status of the computer and it's need for being defragmented) You can run an analasys to determine if it need to be defraged. This can be done under the Start Menu,All Programs, Accessories, System Tools,Disc Defragmenter: When Disc Defragmenter Opens, it will give you a list of the internal (hard drives,including the D:/ Partitioned Drive) Select C:\ and click on Analyze. This should only take a few minutes to complete. Once the Analysis is complete, it will tell you directly whether or not the computer (Drive C:\) needs to be defragged. In the event it does not, You can also run a Disc Cleanup: Go to Start Menu, All Programs, Accessories, System Tools, Disc Cleanup. Be careful doing this as you do not want to remove any programs that you use on a regular basis, or frequently, that the computer automatically may deem "seldom used". Here, you can remove, or uninstall programs and files that you or the computer do not need, and free up space. Freeing up memory or space will improve speed a little bit. Depending on the OS (operating system) and it's current grade (upgraded or not) - you may need to have more memory and RAM installed.
May 09, 2008 | Gateway 40G / 40GB for laptops /...
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
