Question about Maytag Refrigerators
I have a Maytag refrigerator model # MTB2156BEB that leaks water from the bottom of the refrigerator door> I think the drain plug is clogged. I need to know where it is and how do I clean it.
    Sergeant:
  • 222 Answers
This is most likely drain off water from the automatic defrost cycle.
There is a removable drip pan under the refrigerator that can get filled with lint and mildew and keep the water from evaporating properly. There is also a fan which pulls air across the condenser coils but also serves to help evaporate the defrost water.
Remove the drip pan and clean it out, clean off the coils with a brush and vaccum, and be sure the bottom fan is running. That should solve your problem with ZERO dollars out of your pocket.
Good luck. Hope this helps.
Posted on Sep 12, 2009
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water leaking from freezer side of side by side refrigerator..model MSB2354AR
Sounds like a clogged drain, If ice is on bottom of freezer floor then it is def. a clogged drain. Remove rear panel and clear drain of ice and possible obstruction.
Feb 08, 2010 | Maytag Refrigerators
This is model MTB2154AR. The top freezer is
sounds like an air leak in the gasket or a clogged drain or both-mike
Jan 22, 2010 | Maytag PTB2154G Top Freezer Refrigerator
Leaking water in front left side
hi tom
yes the drain tube may be glogged and when the unit defrosts the water just flows to the bottom of the un it then eventally out, if you have a clogged drain, you will see water on a pretty reglar basis
8, 10, 12 hours
the drain pipe is behind the back wall on the freezer, if you take that off you will se an ice build up, remove that ice and clear the drain tube
you may need to pull out the machine and remove the tube from the back to ensure that it is entirley clear
Oct 20, 2009 | Refrigerators
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Oct 07, 2007 | Refrigerators
Refrigerators Logo
246 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
