Question about Kirby Ultimate G Bagged Upright Vacuum
I cant get the water solution to come out of the tank
  • 34 Answers
You must of put the tub on wrong. other wise it would be working fine
Posted on Sep 12, 2009
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Cant find heater in bissell 8920
I have one and watched a video on youtube that shows the red washer in the improper place under water tank. It shoed in unit base. He removed with screwdriver and placed back on nipple on the water tank and it worked.
Jan 21, 2014 | Bissell Brushroll Proheat 2X 8920 9200...
I have the hoover steam vac f5906900 and im just trying to use the detachment. I plugged in the water part but i cant get any suction. the water is spraying out that is all....help my dog **** on my bed...
Hi, The attachment hose also has to be plugged into the dirty water recovery tank. The other end of the hose which has the square plug, must go in the spot on the recovery tank where the water comes up from the floor. To do this, Remove the lid of the recovery tank, slide out the little rectangle (usually same color as the recovery tank) which is located just above the clear water channel from the floor there, and insert the square piece for the attachment hose. It should only fit in one way. Replace the lid to the tank and you should be ready to attack the ****. Good luck. Mark
Nov 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Top water bottle want stay in
The black base that the bottle sits in is broke. You can use hot glue to replace the bottle. I would suggest buying a new tank from hoover because the style of tank you have has a known design flaw. They have redesigned the tank to be stronger. You could trying calling the Hoover company and complaining. I know that has worked in the past.
Apr 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel powersteamer clearview will not spray water
Did the gasket on the bottom of the water tank come off and is either missing or sitting in the hole where the tank sits? It needs to be on the tank.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jun 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
No water or any kind of spray coming out
Could have a bad pump, but first remove the spray nozzles and blew thru them to make sure they are not clogged. Make sure that the gasket is install on the valve on the bottom of the tank and not sitting in the hole where the tank sits.
May 31, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 8920 will not suction water.
Go to a Bissell service center and ask for it or maybe call the customer service support line that is listed on the vacuum.
http://www.bissell.com/Service_Centers.aspx
Feb 24, 2008 | Vacuums
Tank not sitting tight
some bissell models this cant really be fixed but some can look at where the tank connects some bolt down some twist in and some have a rubber gasket between the the tank and the machine if this is the case, with the age of the machine the rubber gasket is probably worn out. try replacing it. that gasket flattens out with time and the connection gets loose and it sucks air and dont work. when you said if you pushed down on it it wotked that is a good sign that the gasket is shot. if nothig else find one that you can fit to the machine that will eliminate the loose fit. this will fix your prioblem.
Dec 05, 2007 | Bissell 8910 ProHeat Clear View Upright...
Kirby Ultimate G Bagged Upright Vacuum Logo
22 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
