Question about Bissell 3522 PowerForce Bagged Upright Vacuum
Bag full indicator light on only when I plug the hose back in...
I unplug the hose and the light shows green, I plug the hose back in and the light shows red. I have checked all the filters and cleaned all the hoses out as well as I could get to.....what is up?
  • 120 Answers
Drop a marble or something similar through the hose to see if its clogged
Posted on Sep 14, 2009
Red light indicates bag is full when it is not
you could have vacuumed up a fine powder that is clogging the bag.
Oct 08, 2014 | Vacuums
3 lights show up on the top of my vacuum and the center one I don't know what it stands for. Plus, the vacuum seems to be getting too hot.
The one that looks like a cord plug lights up when the vacuum is plugged in and indicates it's getting power.
The one that looks like a thermometer lights up when the vacuum is overheating, and indicates there's probably a clog in the hose or power nozzle behind the brush.
The next one indicates there is no bag in the vacuum. Machine will not run.
The last one indicates the bag is full and needs to be changed. A full bag or clogged pores will result in overheating, however the vacuum automatically turns off when this happens to protect the motor.
It sounds like you need to replace the bag. If you still have problems, it's probably due to an internal part called a control valve assembly. That is an in shop repair, and the vacuum needs to be taken to an authorized Aerus Electrolux store for service. This is most often due to "made to fit" bags being used instead of "genuine" bags. In this case the motor and interior of the machine need to be cleaned as well. Dirt, even fine dust, in the motor will shorten the life of the motor dramatically.
Dec 02, 2010 | Electrolux Epic 6500 Vacuum
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is suction.is your brush roller turning.no suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
Vacuum shuts off, bag light on, runs fine without hose connected
I'm not sure if I understand your problem completely, but if it is your full bag indicator that is coming on, even with a new bag, it's probably your control valve. These can be replaced by your dealer. When working correctly, the control valve should trigger the off switch when the differential pressure gets too great between the front of the bag housing and the area behind the bag. When it goes bad, it will indicate that you need to change your bag, even when you don't. Good Luck!!
Oct 30, 2008 | Electrolux Epic 6500 Vacuum
It does not ****
Greetings from GoVacuum.com,
It sounds like you have a clog in the vacuum cleaner somewhere. What you can do is remove the hose from the back of the vacuum cleaner and see if the changes the bag full indicator, and pay attention to the sound of the motor. If the motor starts making a high pitch sound as soon as your install the hose, this means that there is a clog somewhere in the hose.
If you can give me your model number, I can send you a parts schematic to your vacuum cleaner.
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
128 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
