Question about Symbol PDT6842-NIS632EU Portable Data Terminal
PDT 6840 When using these units in dhcp boot mode the mu ip address stays on one address (fatal adress already in use) and will not grab another address.This causes the error tcp is down to be displayed on the screen.
  • Anonymous Mar 27, 2014
    Ip address
    Problem Solver:
  • 5 Answers
By definition the MU gets it's IP address from the DHCP server. If it's getting an address that's already in use, then it's the DHCP servers fault not the MU. I would look at the server and make sure it has enough available IP addresses to go around.
Posted on Apr 18, 2008
My ip adress says unavailable
Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
Jan 07, 2014 | Computers & Internet
Tip
How to obtain public IP from Time Warner
<p>There are two basic types of IP addresses of internet service providers (ISPs) to provide customers with Internet services: a dynamic address or DHCP and a static IP address. A static IP, as the name implies, uses the exact same IP, and you're online all the time. The DHCP IP configuration uses a "stack" of available IP addresses each time a modem is online and an IP address of the network of the ISPs is simply grabs the first available IP address from the stack. The IP configuration of DHCP, then it is very easy for a new public IP address from your provider at any time <br /> <p><br /> <p>1. Unplug the cable modem from Time Warner. Total count of 30 seconds and close. <br /> <p><br /> <p>2. Allow the modem to reboot every five minutes. During this time, goes through the boot cycle, contact your provider and ask for a dynamic IP address. <br /> <p><br /> <p>3. Navigate to the computer's IP Configuration Manager. For most versions of Windows, the easiest way to do this is to open the Start menu, click All Programs, then select "Command Prompt" from the "Accessories" menu (for future versions of Windows, you may need to the right button on the Command Prompt and select Run as Administrator "to show itself sufficient permissions on IP of the computer information). <br /> <p><br /> <p>4. IP address to test your computer by typing "ipconfig" and "Enter" Command to the numbers printed next to "IP address", like "IPv4 or IPv6 address." The number displayed on the public IP address of the DHCP as the modem from Time Warner will receive net. <br />
on Jun 22, 2011 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Someone else is using my ip adress
it is possible that your router gave out a duplicate ip address or that your using a static address and the router is giving the ip address you are using to another computer.
please check that your computer is setup to DHCP or that the other device/laptop/pc is set to dhcp or obtain dynamic ip address.
Sep 26, 2011 | Toshiba Satellite P105-S6197 Laptop
We already have Avaya 4610 IP Phones at one of our site and trying to add 10 more 4610 IP Phones, but after i connect these phones, it's going to DHCP mode and allowing me to do mute r,e,s,e,t or dosen't...
You have to be fast. When the phone boots up, it will grab DHCP for 4 seconds. During that time you can press *.
Or, you can wait for teh phone to fully boot up and connect to then system, then do it.
Jan 26, 2011 | Avaya 4610SW
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
I want to secure my wireless network so neighbors coannot use it
type your ip adress into you web browser, this should take you to the configuration screen, there should be a tab that says security or something like that, select the type of security that you want, and it should assign you a wireless key automatically, hope this helps
May 15, 2009 | Siemens SpeedStream 4200 (13A4200001)...
I DONT KNOW HW TO CONFIGURE THE IP ADDRESS IN DOS MODE SO PLZ .HELP ME...AND GRAND ME THE CODE OF CONFIGURING SYSTEMS .. THANKING U IN ADVANCE SINCERELY FASMIN
You can use the netsh command to configure Ip adresses.
1. IP via DHCP:
netsh set address name="MyLocalAreaConnection" source=dhcp
2. static IP:
netsh set address name="MyLocal AreaConnection" source=static addr=192.168.1.61 mask=255.255.255.0 gateway=192.168.1.1
- no line breaks in the commands
- change names and numbers to your needs
- check on mistyping and spaces between the commands
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
Symbol PDT6842-NIS632EU Portable Data Terminal Logo
531 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
