Question about Sony Handycam DCR-PC115 Mini DV Digital Camcorder
Blue screen showing error code c:31:23
Cant play or record tapes
  • 62 Answers
This may seem silly, but it worked for me. I found this on discussion forum. Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. The mine works too!
Posted on Sep 19, 2009
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
SOURCE: trv340 error code c:31:23
According to page 184 of the owner's manual, any error C:31:X or C:32:X you can fix by removing the cassette and re-inserting it again and/or disconnecting the power cord and removing the battery. After doing both of these steps, I'd also recommend using a paper clip and press the tiny reset button underneath the flip out display where all the other hidden buttons are for the camcorder.
Posted on Jun 21, 2008
mistersony
  • 320 Answers
SOURCE: camera wont play or record has message c:31:23
Basically, the error message indiactes the reels are not turning, either because of a defective tape or a fault in the mechanism. Try a new tape. If the problem persists, you will have to have the camcorder serviced. please be sure to rate this solution. Thanks!
Posted on Oct 23, 2008
truekleen1
  • 46 Answers
SOURCE: have flashing yellow error, error code C:31:23,
Sony says C31 is a Tape Loading Error. They suggested removing the camera battery. Then re-connect and then re-set the camera back to factory conditions. If it persists it may require attention. May also be a mechanical problem such as is the back Rubber wheel in the proper place and the white plastic lock is not there? flip the camera upside down it's come out (the white plastic lock) then place it BACK
It may also be a bent lever. Try the factory restore first.
Posted on Jun 14, 2009
SOURCE: ERROR CODE AT START RECORD C:31:23
C:31:23 s reel error
try to change the tape,actually this problem is related to the tension ,new tape have more tension as compared to the old one(used one).
Posted on Jun 30, 2009
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Sony ccd trv 308 had a error c 31:23 and c 31:22 , beeps when trying to play and record. Found the pinch roller jam inside , took it out and fixed it with heat shrink tube, error gone , camara runs good ,...
Did you possibly hook it up right to your tv? Where was the blue screen. How do you know it recorded anything if your not sure if it works right. Is the tape moving? Sometimes it may appear to be moving and really it's not. Hear isn't a good thing with a tape recording device. I know this might sound trivial, but I would read the directions if ya got them and make sure your not skipping a step. If you record on some machines you have to switch from record back to play mode. Where is the blue screen.
May 20, 2014 | Video Cameras
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
My camcorder screen stays blue when its in play mode.
Try to run a cleaning tape, it should solve your problem.
Aug 15, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony Handycam DCR-PC115 Mini DV Digital Camcorder Logo
121 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
