Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Water does not drain from tub. I think it is clogged and need to know how to clean out the drain.
  • James Black May 11, 2010
    Do you have a disposall?
  • 5,911 Answers
If this is a Whirlpool top loader as you have this listed under, you need to check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If the lid switch checks good, you can still inspect the drain pump if you like. However, there are no electrical connections on this pump and it only has one moving part - the impeller. They do not commonly clog. The steps for removing the washer casing in the link I provided will give you access to the drain pump. It is located directly below the wash tub on the front. If the tub is full of water, an easy way of draining it is to use a wet/dry shop vac and pull a vacuum on the drain hose. If the water drains freely with no restrictions (if restricted the drain line will collapse from the vacuum), the pump isn't clogged. If you don't own a shop vac, simple gravity will also do the trick by placing the drain line on the floor. However, I wouldn't recommend this unless the washer is in a garage or basement where the water can drain somewhere. Once the tub is drained, you can remove the two drain hoses and check inside the pump for obstructions.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete the repair if replacing the lid switch.
Posted on Sep 11, 2009
I can't open the door as the lock symbol always there
Is there water still in the tub? If the main control thinks there's water in tub, the control will keep door locked. If there's water, you might have a possible draining issue. Either clogged drain pump or something clogging drain hose. If no water, possible door lock malfunction or pressure switch malfunction. Good luck!
Aug 04, 2015 | Washing Machines
Washer will not drain after rinse cycle. Water left in tub when wash is finished
There are two typical problems: the drain line is clogged is most common. Unscrew the drain line at the machine outlet and blow through it, if it's clogged you will know. Sometimes the clogg is inside the machine, clean out the lint screen to see if there is a sock caught in there. Unfortunately, if there is no clog, then the water pump is bad.
Mar 12, 2015 | Washing Machines
Water left in tub at end of cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | LG Dishwashers
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
Water does not drain from machine
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
Sep 07, 2009 | Westinghouse WWS833ES Super Capacity Top...
Drain hose on GE washer clogged with sand
Hi, It is easiest if you have a wet/dry vac and **** the water out of the tub. You can also try and **** the water out of the drain hose and hope the plug is small enough that it breaks lose. The most common place the hose gets plugged is where it narrows after the pump going out the back of the washer.
I hope this helps you.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE WDSR2080D Top Load Washer
Washer won't drain -- clean the pump
First I would try to flush the pump, if the tub is still full of water. To flush the pump, take a garden hose sprayer and fit it tight into the drain hose. Give it a short shot of water, then stick the drain hose back into the drain. Put the washer on spin and see if any water comes out. You may have to do this more than once to clear the pump. If that does not work, siphon the water out of the washer and disconnect the hose from the pump to the drum. Clear the hose the best you can, pour a little water into the drum to check it. Check the pump too, take it apart if you have to.
May 05, 2009 | Washing Machines
Hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Jul 22, 2007 | Hotpoint WMA46 Front Load Washer
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
347 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
