Question about Car Audio & Video
Wiring diagram for connection to a kitt avionics adf rx polaris b/ beechpart 8711a ser 3471 fixed loop
I need the wires conection for panasonic car radio model cq-rdp103N
Any body can help tome sending this information?
Posted on Sep 12, 2009
I need a wiring diagram as my son connected the battery wrong negitive to positive need to see what all is wrong
There is a fuse link at the Positive battery terminal wire. It will blow to protect the circuits if the battery is hooked up backwards.
It is a smaller gauge section in the wire that melts to save systems. any auto parts store has one
MDS
Mar 26, 2016 | Polaris 2004 Sportsman 500 H.O
2001 Sportsman 500. Where can I get a wiring diagram?
I'm attaching a picture that has 2 wiring diagrams side by side. The left side is the 2000 Polaris Sportsman 500 (Early) wiring diagram and the right side is the 2000 Polaris Sportsman 500 (Late). The Late wiring diagram for 2000 is more than likely either the same or extremely close to the 2001. And they may have just carried it over (the late wiring diagram). I've got a lot of hours on ATV's and Polaris especially - they stuck with what worked and didn't reinvent the wheel from one year to the next (usually). This may not be exact - but it should be extremely close. Hope this helps. Good Luck.
All The Best, Justin Lee
Nov 10, 2015 | Polaris ATV
Where can I find the wirring diagram for 12 volt reversing camera
i think it goes
Polaris Red-Camera Yellow Polaris Black-Camera Black Polaris white-Camera white and polaris Green-camera bare hope this helps
Nov 24, 2014 | Car Audio & Video
Wire diagram samick gregg bennett guitar
Here is the wiring diagram for a 2 humbucker, 2 volume, 2 tone, 3-way switch setup. The wires off the pickup may be a little different. Just attach the lead wire to the arm of the pot and the ground to the ground on the top of the pot. Should be very strait forward.
http://www.seymourduncan.com/pdfs/support/schematics/2h_2v_2t_3w.pdf
Nov 07, 2011 | Samick Greg Bennett Avion AV-3 (Black)...
I am replacing an old booster pump with a Polaris PB4-60. I have three wires, One Red, One Blue, and One Green. Now I know the Green is Ground, but which poles do the Red and Blue go? Both seem to say...
It is impossible for us to know what voltage you are running as you did not list that information here.
Typically a green-red-blue comination of wiring suggests 240 VAC connections.
Also, every motor you buy is required to have a wiring diagram on the side of the motor. This should tell you where to connect the wires.
IF you are running 240 v as suspected, both the red and blue wires are "hot" wires on the load side of your timing box. Simply look at the side of the motor and follow the diagram on wiring the pump.
Typically most motors in the USA use a L1 and L2 terminal to connect the 2 "hot " wires.
This pump does come factory wired for 240 volts, so it probably is just 1 each of the "hot" lines to L1 and L2.
Before connecting, make sure you confirm your systems voltage with a multimeter.
Below is a link to the installation manual for this pump. But it does not list electrical diagram since its on the side of the motor.
http://www.clubp.info/pdf/TL/P-134.pdf
Mar 22, 2011 | Polaris Pb4 - 60 Booster Pump
How do I connect an external AM antenna
G'Day
The AM loop antenna needs to connect between the terminals marked as "AM ANT" and "GND" on the rear top right corner of the amp. This is the normal configuration for a loop antenna. The other option(not using a loop antenna) is to connect "GND" with a single insulated wire to a decent earth connection (2 m copper stake hammered into the ground or a water pipe, and a single wire elevated as long and as high as you can. this style of antenna system is not generally used these days, as the transmission power of radio stations has increased greatly over the years so that a small loop antenna will do the job So, most stations should be tunable with just the loop, remember however, that it will be directional. If the loop is in proximity to other electronic gear, it may not perform as well. Keep it as far away from the rest of your gear as you can.
You will generally get no AM stations AT ALL until you have connected the loop to both terminals. Happy to talk to you further about this. Please rate my solution. Cheers
regards robotek
Apr 08, 2010 | Yamaha HTR-6130 Receiver
I broke a bunch of the wires on the wiring harness
You need to get yourself a shop manual and rewire the harness in accordance with the wiring diagram in that manual. I bet if you look online you can download it for free like I did.
Oct 02, 2009 | Polaris ATV
Unplugged wires from a 89 Polaris trail boss
go to www.bikebandit.com and click for oem parts than go to polaris and year etc.. they have exploded diagramsof the machines from front end to electric system good luck
Sep 29, 2009 | Polaris ATV
Looking for wiring instructions for the replacement polaris pump motor. It says it is wired for 240 and I need the configuration for 120. It is polaris booster 3/4 hp pump.
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Apr 24, 2009 | Polaris Pb4 - 60 Booster Pump
Car Audio & Video Logo
289 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
