Question about Sharp AL-1655CS Laser Printer
Error L1-00 CAn I unlock this error code for the scan head?
  • NanaMichele Jan 23, 2008
    l1-00 problem. seems as if the scan head stops is wrong spot on left and sends out that message. removed plastic locking device for scan head and receive same message with or with out it in place (even though it is not locked)
Yes, ,there is a clear plastic round thing where the paper comes out uder the scanner that locks or unlocks the scan head. turn it to unlock.
Posted on Dec 22, 2007
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
How to fix error code u051 cannon printer mp480 error code u051
Reset the Print Head:
Make sure that the power is turned on, and open the Paper Output Tray gently
Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
Remove all the Ink Tanks in the following manner.
Push the tab (B) and lift the ink tank to remove.
Do not touch the Print Head Lock Lever (C).
Raise the print head lock lever.
for other more help click https://cbrtechsolutions.net
Oct 17, 2011 | Office Equipment & Supplies
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
L-1 error code.
Turn the copier off and remove the scanner glass. Sometimes the ribbon cable underneath the scanner gets bound up on the scanner. Flatten it out and secure it with scotch tape. make sure that the loop has enough slack on it for the scanner to travel freely.
Oct 06, 2008 | Sharp AR-153E Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Where is the scan head locking switch
hi dear
Release the scan head locking switch.
The scan head locking switch is under the document glass.
If the switch is locked ( ), the machine will not operate. Unlock the switch
oke
cropp
Mar 19, 2008 | Sharp SHP AL1655CS Printer, Scanner,...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Sharp AL-1655CS Laser Printer Logo
388 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
