Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Our Dometic RV Roof Air Model #600315 will not blow cold air. We were told that the controller would not activate because of a compressor lock up. Do we have to replace the entire air conditioner or only parts?
  • 1 more comment
  • dallasronh Sep 12, 2009
    The unit is a little over 3 years old. Since it is not really old would it be worth while to replace just the compressor?
    Also, if we have to replace the whole unit is there a more reliable make and model? We do have a height issue. Our motorhome is parked under a carport with a maximun of 10'10" clearance. Our mothorhome has a height of `10' 7".
  • dallasronh Sep 13, 2009
    thaks so much for your advise and also for the phone number for Dometic
    Thanks for all your advise and the phone number for Dometic. I plan to contact them tomorrow.
  • 3,361 Answers
Hello, dallasronh.
If the compressor is locked up it would cost less to replace the complete unit. Prices for complete units average around $500.00.
The compressor alone sells for over $300.00 Then there are accessories such as filter drier and refrigerant and capacitor plus about 2 hours labor from a service technician. Repair cost would exceed replacement cost.
The existing compressor controls can be by-passed for test purposes to verify a compressor lock up. Ask the technician if he verified by using a power cord directly to the compressor and capacitor.
I am not sure what you mean by "controller".switches,thermostat,circuit board??
If it is a part he is talking about and not a bad compressor you would spend up to $250.00 for parts and labor.
The rule of thumb is to spend up to 50% in repairs versus replacement cost.
Thank you for using FIXYA.
Posted on Sep 13, 2009
  • steve
    steve Sep 13, 2009
    Dometic is a good brand name. No brand is without issues. Coleman would be a good replacement. First,check your warranty. Your compressor(sealed system) may be under a 5 year warranty.
  • steve
    steve Sep 13, 2009
    1-800-544-4881 Dometic service support number.
    President:
  • 1,124 Answers
If the air compressor is locked up - you "could" get it replaced.. However - if you do that - the other components could fail eventually.. Also depends on the age of the unit.. It might just as well be best to replace the hole unit.. If it is an older unit - you might consider replacing the hole unit.. Then you will have a warranty also..
Did you have a pro test the components ?
Did they try a "hard start kit" to maybe jump start the compressor ?
Good luck ;o)
Posted on Sep 11, 2009
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic Duo Therm rv Roof Air Conditioner Model# 59516.531.The fan is blowing and the compressor is kicking on but it is not blowing out cold air. Someone said it must be out of freon. Why would...
These are a closed system.(meaning that there is no fill valves for recharging) But a heating & cooling technician can solder them on and re-charge the system. Only problem there is to get an estimate up front, and compare it to buying a new roof unit which also comes with a new warranty, as well as keep in mind that the freon went somewhere, so there is an obvious leak that will need to be addressed as well. Most times it's wiser and cheaper in long run just to buy a new roof unit.
Are you sure that the compressor is kicking in? Did anyone remove cover on roof and check lines from compressor to see if any cooling is occurring?
These don't often leak, that's why I'm asking. Any idea how old the unit is?
Perhaps in fairly new, it's a warranty issue.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
I have a 13,500 Dometic A/C that usually blows cool air but sometimes changes sounds and blows hot air for a while before switching back to cold. What do I need to fix?
Could be the compressor overload on the way out. Or an intermittant temp control. Or it might just be a loose connection at the junction box between the roof and the base.
May 04, 2010 | Dometic Rooftop RV Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Rv air conditioner
Check the temperature control and see if it clicks when you turn it off and then back on. Check to see if the compressor is running. If the compressor is running but not cooling you may have a leak and lost the refrigerant charge.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
90 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
