Stalling 96 sunfire starts and runs for 3 seconds and dies
    President:
  • 353 Answers
If it starts up fine and then dies (2 SEC) it is the PASSLOCK security system, those cars are fairly notorious for that problem.
The passlock system will cut power to the fuel injectors after 2 sec. Use a test light and see if the injector power is being shut off.
Posted on Sep 11, 2009
    Problem Solver:
  • 7 Answers
Sounds like a faulty fuel pump or a clogged fuel filter
My 96 Ford windstar was running just died in the middle of the street I bought a computer thinking that was the problem it cranks but won't fire
Ford Windstar Starting/Stalling Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... Then on Friday it died while I was driving down the street. ... I have a 3.8L v6 1996 Ford Windstar. .... Then yesterday the car just died while driving and had to be towed back to .... The engine will crank, start run about 5 seconds then stop.
Fixing A Car That Randomly Dies While Driving - YouTube
? 3:59
https://www.youtube.com/watch?v=zwlruD4JXmY
Jul 20, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Randomly Dies While Driving. Scotty Kilmer ...Just check it out at https://www.youtube.com ...
2002 Ford Windstar Engine Stalls/Shuts Down While Driving ...
www.carcomplaints.com/Ford/Windstar/.../engine_stalls_shuts_down_wh...
The 2002 Ford Windstar has 11 complaints for engine stalls/shuts down while driving. ... 2002 Windstar just starting shutting off in the middle of driving. ... The engine diesupon acceleration and will crank but won't start unless switch is ... Inspected the Fuel Pump shut-off Switch, Fuel Filter, Run several full tanks of gas ...
Jan 26, 2016 | Ford Cars & Trucks
Why is my epica stalling after a few seconds
Does it start back and die again? It could be a computer malfunctioning,I would say maybe plugs/wires but if that's all its running is 3 sec.idk, usually plugs get hot and file out and cause your vehicle to shut off...
Feb 21, 2015 | Cars & Trucks
1998 pontiac sunfire manual. Car starts but sputters and then dies and is completly dead but in the morning will start again and then die. I changed the coil pack but still the same. what can it be?
You can't do any testing, until you have a battery
that will take and hold a charge
Then you move on to testing the Alternator,then
Fuel Pressure & continue on with other testing
Apr 04, 2013 | 1997 Pontiac Sunfire
My 1999 sunfire gt starts and runs for a second then dies what can i do to fix this problem??
GM vehicles like your sunfire are notorious for failing antitheft systems called passlock. When this system fails, you get what you have. The engine will start for 5 seconds or less and then stall and shut down. There is a dead giveaway for this problem, after it stalls you'll see a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that explains your problem. Here is a link that will help you.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 12, 2012 | 1999 Pontiac Sunfire
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 07, 2011 | 2004 Pontiac Sunfire
MY 96 PONTIAC SUNFIRE 2.2LITER WONT START AFTER IT RAINS OR IT WILL STALL OUT AFTER BEING TAKEN THROUGH AUTOMATIC CARWASH ANY SUGGESTIONS ANYONE?? THANKS!
check spark plug wires and coils for moistore put some lube on the coil wires check for spark after it wont start if itll crank but not start its 1 of 2 thinks no spark or no fuel usally when the coils get too wet they wont allow spark to come through or will cause it to arc
May 07, 2010 | 1996 Pontiac Sunfire
Passat 96 tdi , only runs for 2-3 seconds
i have 2 keys for my passat.with 1 key the engine runs perfect and with the other key the engine runs 2-3 seconds
Jun 16, 2009 | 1999 Volkswagen Passat
Car will no longer start!
Well, does this happen often, the engine failure? I'm not there in person, but I can lead you to an article that addresses what seems to be the cause of your car problem, and that is a malfunctioning connector between the electronic control unit and the distributor of the vehicle; here's the article link:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Abruptly_Quits_Periodically_While_Driving.htm
If, on the other hand--since putting gas into the gas tank was the last thing you did before you had a problem--consider the possibility you mistakenly read your gas tank gauge and unknowingly over-filled your gas tank, causing the problem you have been suffering right afterwards, as noted in this second diagnostic article: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_With_Carburetor_Hard_To_Start_After_Filling_Up_Gas_Tank.htm Good luck!
Brad
Jun 08, 2009 | 1996 Pontiac Sunfire
96' sunfire changed engines 2.2 starts dies theft light comes on
The problem is the new PCM you installed does not have the correct VIN number of your car.
You may be able to relearn the VIN using the preceedure below, however, there is no gaurentee it will work. You may have to have a dealer reset the VIN for you by way of a scan tool.
1) Instert key into ignition and rotate to run position (do not try to start engine)
2) Leave the key in the run position for 10 minutes until security light stops flashing.
3) Turn ignition key to off position for 10 seconds ( no more, no less)
4) Turn ignition to run position again for 10 minutes until security light stops flashing and repeat step 3 and 4 for (1) more cycle.
The process is a security verification step for the VTD system. ( Vehicle Theft Deterent)
Give it a try, let me know.
Regards,
May 04, 2009 | 1996 Pontiac Sunfire
96 Sunfire won't start
gue$$ing isn't the route to costly you must have engine light on OBD 2 scan for the fault and repair! if no engine light could be not working usually these come on every time something happens!!!!
Jan 01, 2009 | 1996 Pontiac Sunfire
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
