Question about Refrigerators
Unit does not cool
I have a Le Cache wine cooler with a Breezaire cooling unit. The cooling unit runs but does not cool.
  • 21 Answers
It would appear that the unit needs to be regassed and checked for leaks.
Posted on Sep 11, 2009
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Unit is not cooling. there was dust on the coils that i cleaned off. Now the unit wont cool and there is a dot next to the temperature which is 76
UNPLUG FOR 15 MINUTES AND REPLIUG UNIT IT SHOULD RESET UNIT, DOT IS A DELAY MODE FEATURE OF THE UNIT, YOUR UNIT IS NOT A WKC IT IS A WKCE1060
Jun 19, 2011 | Breezaire WKC1060 Wine Cellar Cooling Unit
Evaporator ices; unit does cool
TWO POSIBILITIES
ONE IN MAJORITY OF CASES IT IS A SYMPTOM OF A FREON LEAK, ICE FORMS ON COIL, UNIT MAKES NOISES AND IT WILL GRADUALLY LOOSE COOLING RUN NON STOP AND THEN IT WILL PRODUCE HEAT
SECOND
A BAD FAN ON THE COLD SIDE OF UNIT THAT REDUCES AIR FLOW PASSING BY THE COIL AND ALLOWS IT TO FREEZE, IN THAT CASE IT WOULD NEED A FAN REPLACEMENT, YOU MAY CONTACT THE MANUFACTURER FOR A REPLACEMENT FAN
May 16, 2011 | Breezaire WKCE 2200 Wine Cooler
I need a wiring diagram for a Breezaire WKE 8000 wine chiller/cooler. Does anyone know where I can download one?
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Mar 16, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
My 2200 unit stoped cooling why
IF YOUR UNIT IS A WK2200 IT SHOULD HAVE A SCREW ADJUSTMENT(THERMOSTAT) IN BETWEEN THE TWO BROWN GRILLS. IF SO IF THE FANS ARE RUNNING ON BOTH SIDES COLD AND HOT SIDE, AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK AND THE UNIT REQUIRES A RECHARGE AFTER REPAIRING THE LEAK.
Jan 17, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Unit runs but does not cool.
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Oct 25, 2010 | Breezaire WKL 4000 Wine Cooler
I have the 8000 WKL Breezaire it has started to frost up over and over. I turn it off to melt and it starts to frost as soon as it starts to cool the wine room. Why?
IF THE BLOWER ON THE COLD SIDE IS NOT RUNNING THAT WOULD BE THE REASON WHY THE COIL FREEZES UP AND IT COULD BE DUE TO A BAD BLOWER CAPACITOR LOCATED ON THE BACK OF THE UNIT LEFT SIDE (SMALLEST OF THE TWO OVAL CANISTERS), BUT IF THE BLOWER IS RUNNING ON THE COLD SIDE IT MOST LIKELYIS A FREON LEAK, AND UNIT NEEDS TO BE RECHARGED WITH FREON AFTER REPAIRING THE LEAK.
Sep 27, 2010 | Breezaire WKL 4000 Wine Cooler
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
