Question about Maytag Neptune MAH9700 Front Load Washer
MAYTAG NEPTUNE ERROR CODE OE
MY MAYTAG NEPTUNE IS SHOWING ERROR CODE "OE" WHEN I CALL THE MAYTAG HELPLINE THEY CAN'T FIND THE CODE.
  • Anonymous Mar 16, 2014
    Maytag Neptune reset code
    President:
  • 1,776 Answers
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 11, 2009
I have a Samsung Washer and the water would just keep pouring in and not stop. Eventually the OE error code would show and I would have to stop and turn off the water.
Thanks so much. You can fix this problem yourself. There are only two screws holding this part on. It is easy. I bought my part here.
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4044218
Nobody stocked the part for the samsung but I found out that the Whirlpool part was exactly the same.
Posted on Sep 25, 2009
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
The code F25 shows up
Are you sure about that error code? My Maytag Neptune manual does not show any F error codes.
Jun 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Error code 0e
Hi, it is the pressure switch aka water level sensor. OE is overflow error. Pressure switch is located under top cover on front right hand side. It is round and has a rubber tube leading down to the drum and a electrical connection to the board. Paid maytag man to diagnose/install cost me about $150.
There is a recall on the circuit board for certain Maytag Neptune washers. See the link below:
http://www.repairclinic.com/0098_11.asp
Take care
Jun 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
Washing displaying OE error code
here's a link to a service manual for you particular model seems OE is an overflow error, this will help you trouble shoot your problem. ( im current ly downloading this manual for my own reference )
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Mar 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Mar 23, 2008 | Washing Machines
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
4,652 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
