Question about Dishwashers
Whirlpool GU1500 XTLS Dishwasher, need control panel part number
Need Control Panel Part number, then need to buy part online at the best price.
  • 33 Answers
Just go to this site and you will find the part you are looking for.
http://tiny.cc/z5Sy6
Posted on Sep 12, 2009
Testimonial: "Love that he told me what part he thinks it is but why is ther 3 different parts that look exactly the same on this page he sent me to. Very Confusing"
Maytag MDBH945AWW: control panel was a bit erratic and now doesn't function at all. I pulled the flex circuit panel off and see that under the cycle select button is some brown gooey stuff. The other...
I have the same dishwasher. I have found that this dishwasher had a control panel problem. After the dishwasher finishes washing you will noticed that the small green lights stay illuminated. Over time this causes the wire ribbon that connects the control panel to the circuit board to become burnt. I have already replaced my control panel once and now it has done it again. i am about to have to order another control panel. That is going to be another $140 dollars out of pocket. The part number for the control panel is( AP4365240). If you have the same dishwasher as I do it should be correct, Open the front door and look on the inside left and you will see the model of the dishwasher. Mine is MDC4650AWB1 Yours may be slightly different. look on the front of the control panel to see if it reads from left to right. High temp wash or extra rinse, sanitize, heated dry, start/cancel, delay, and cycle select. Since the dishwasher is designed poorly and the lights do not go off after drying, if you can after the dishwasher finishes with it's washing and drying be sure to open the door for about 2 min and the lights will go out by themselves. Then you can close it back. This will allow your dishwashr to last longer without the wires burning out. To verify that it is the control panel after you carefully remove it take a look at the wire ribbon that runs from the control panel to the circuit board. Here is a quick class on how to remove the control panel. open the door and on both sides you will find 4 star tip screws. remove them and seperate the door from the backing. After that you will need a socket to remove some hex tip screws that holds the control panel to the door. be sure to remove the black box that contains the circuit board. take the cover off and carefully disconnect the wires. the wire ribbon that connects the control panel is a little tricky. You have to seperate the plastic connector block and the ribbon will slide right out. after you remove it go to http://www.appliancepartspros.com/Appliance-Parts/whirlpool-panel--con-item-number-ap4365240.aspx and you will be able to order the part online to replace it. Be careful not to drop any of the screws and also pay attention to the door latch when you move it to the side while you work so that you do not break it.
This is a response to another similar question but it looks like the same prob. I have found that you cannot just get the buttons you need to get the control panel assembly. Iit it the "flex buttons" they are stuck on by some type of adhesive to the plastic panel. I found that if you just peel off the buttons it messes them up. you need to remove the plastic panel in order to disconnect the control panel from the circuit board.
Aug 20, 2011 | Maytag 24 in. MDBH955AW Built-in...
My control panel went dim at first and eventually wnet completely out. Oven still works and so does oven light. Whirlpool suggested thermal fuse or control panel problem. Any thoughts?
I would replace the control panel...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 19, 2011 | Whirlpool RBD275PD Electric Double Oven
Hear a humming sound when the dishwasher turned on. The panel seems to be ok. Model is GU1500'
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Maytag MDB6701AWS dishwasher and the control panel is not responding, the lock light is on but it is not responding. I had the same problem less than a year ago and they said the control panel was...
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Aug 08, 2010 | Maytag MDB6701AW 24 in. Dishwasher
I have model number KUD 101TJBL0. I have spent about 300.00 on repairs. It keeps blowing the thermal fuse. I have had it replaced sev. times. My repair man has given up on solving the problem. I did read...
This applies mainly to Kenmore Dishwashers with the model number 665.15835791 but also to any Whirlpool or Kenmore dishwasher with an electronic display. There are several possible trouble makers on this dishwasher that can cause this problem and we'll go through the most common ones.
1.Bad Door Latch Switches.
There 2 switches you can buy them from online vendors.
2. Blown Thermal Fuse
The thermal fuse is located in the control panel, called out as item #18 in this picture. You can check it with a simple continuity test. Or you can jumper it out to see if the dishwasher will start running normally. If it's bad,
http://www3.sears.com/Paul/Leadimage.asp?productTypeID=0130000&brandID=0582&modelDesc=DISHWASHER&modelNumber=66515835791&documentID=10058594&documentTypeID=PLDM&documentClassCode=PM&titleType=FRAME%20AND%20CONSOLE&titleID=00001&
3.Control board problems can stem from **** and noise in the dishwasher's electrical supply which make the electronics on the control board go flakey. This problem has been documented by Whirlpool in a tech memo (if your Kenmore model number begins with 665 then, yes, Whirlpool made your dishwasher). Or, it could just be a bad control board, plain n' simple.
The above one is a generic solution, also applicable for Kitchenaid Dishwashers.
The best online vendor as per user reviews :-
http://www.repairclinic.com
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
DO ACCEPT THE SOLUTION IF 100% SATISFIED.
Sep 18, 2009 | Dishwashers
Quote from Local Vendor
depends on what he is required to do to gain access to the control panel. if you are handy with tools and are comfortable doing the repair... buy the part and replace it yourself.
Robert
Sep 15, 2008 | Viking DFUD142 Built-in Dishwasher
Tool to take off panel
Which panel? Why? Most of these screws are either Philips or 1/4 inch head units. Remember to turn off the power.
May 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Mar 09, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
