Not printing left side
Printer not printing on left side of casio pcr-t2000a. journal is printing though.
Clear paper jam pcr t2000
It\'s very unusual for the paper to jam as this machine uses a clam shell type of printer. Just raise the printer arm and remove the paper roll. Clear any paper from the print head and roller etc. Tear any wrinkled paper from the roll and then refit the roll with the shiny side of the paper towards you. Lay the paper in the printer and close the printer arm down onto the paper. If you are setting the journal side, wind some paper onto the takeup spool after it exits the printer and sit the spool into place.
If anyone needs a Casio PCR-T2000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Jul 08, 2014 | Casio Parts Cash Register PC Desktop
Where do I locate the PCR-T2000A cash register batteries. I want to reprogram the machine
Under the platten arm for the journal. If you lift the right hand arm under the printer cover, you will see a small black battery cover. Just remember, you will lose all settings if you do this, so make sure you understand the manual before you do. You will need to set machine features again. Good luck.
If you need a manual, http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Sep 17, 2011 | Casio Parts Cash Register PC Desktop
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
My journal spool for a pcr-t2000a has broken and I can't seem to find a replacement.
If it is just the small disc that slides on the end, you can often get away without it. Otherwise, you need to contact a Casio dealer in your area to obtain one.
Jan 13, 2011 | Casio Parts Cash Register PC Desktop
My take up reel for my casio PCR-T2000A is broken and I cannot find out where to purchase another one? Any suggestions?
This part must be obtained from a dealer. Check the phone book for a Casio agent near you. ----------------------------------------------------------------------------------------------------
Does anyone need a manual for a Casio PCR-T2000 ? Try c-tech: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
May 19, 2010 | Casio Parts Cash Register PC Desktop
I am getting error 35 on my PCR-T2000a and nowhere in the manual does it say how to fix...or that I can find. Can you help?
Hy,
Here is your PCR-T2000a manual.
PCR-T2000a
At page 81 you will find what your error means and what you have to do.
I hope i was helpfull
May 06, 2010 | Casio Parts Cash Register PC Desktop
I have problem with my casio pcr-272 register...I could't find the way to stop printing receipts.Receipt paper& ink getting wasted unnecessaryly when ever I ring something on my Reg.I just need the...
Hi.
I don't have information on this model, but it sounds like it is one of the very low end registers. These machines can not have the printing turned off. They were designed to be journal printers or continuous receipt printers. You need to buy a machine with receipt memory to get this function. (PCR-T series and above)
Mark
Oct 12, 2009 | Casio Parts Cash Register PC Desktop
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
