Question about Camping, Backpacking & Hiking
I can't seem to be able to remove the bulb in my 3 D cell Mag?
  • 56 Answers
Try pressing down and turning the bulb left or right at the same time. It should come out. Good Luck
Posted on Sep 12, 2009
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
3 cell mag 1 battery came out the other are stuck. how do i get them out?
Hello, don't bang on the mag lite. Take a four inch deck screw and screw it into the battery one a time. Once the batteries are out. Mix up some water and baking soda.paste Take the soda paste and applied inside the tube around the corrosion areas. Rense with water and paste serveral times until the inisde of the tube is cleaan. Remove all components from mag lite be starting this operation. Wipe out with clean cloth and skake until al lwater is removed. GB ....stewbison
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
The last battery in my 3-cell Maglight (closest to the end, farthest from the bulb) has leaked acid out inside the tube /handle and caused the battery to get stuck, I can't get it out to clean it up and...
Unscrew the lens and remove the bulb, then get a small disposable container and fill it about an inch full with WD-40, or a similar de-seizing fluid. submerge the stuck end in the fluid for a few minutes and it should come off without issue. Make sure to clean the tube completely before replacing the bulb, lens, and batteries.
Feb 28, 2011 | MagLite Mag-Lite& Flashlight
How do i remove the led bulb in my 3D cell Mag-lite dl
http://www.takeitapart.net/archives/mag-lite-2d/
May 14, 2010 | Camping, Backpacking & Hiking
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
How do you get the bulb out of a 2 D cell
Unscrew the head (the same way, as regulating throw, but much more rotations), then unscrew the nut, holding the bulb. Assemble the same way - nut then head
Nov 15, 2009 | MagLite - Mag Charger System 110v (M)...
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
3 D mag flashlight diagram
Parts diagram is at: http://maglitesales.com/maglitestore/index.php/cPath/12_13
Gary
Jan 16, 2009 | MagLite Mag-Lite& Flashlight
Camping, Backpacking & Hiking Logo
46 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
