What does F26 mean
The washer machine won't start just shows F26
  • 296 Answers
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Posted on Sep 12, 2009
What fauit code f26 mean
This error code indicates that the door needs to be opened and closed.
For a more thorough explanation, check out member Yadayada's explanation here -
My maytag commercial washer display code F26
Sep 20, 2017 | Washing Machines
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
What is F26 mean on my Kenmore frontload washer
Details please does it start washing or what?
Sep 01, 2014 | Washing Machines
F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
May 07, 2014 | Washing Machines
F26 code
Unplug it and wait a while, the door may finally release the lock. Then google the problem to see what F26 is.
Nov 25, 2013 | Hotpoint Ultima WD72 Front Load...
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washing Machines Logo
1,236 people viewed this question
Top Washing Machines Experts
