Turbo whistles in my f f350 diesel
Ford turbo f350 whistles, is that ok
    President:
  • 986 Answers
You wil have a little under boost, but if your sound has changed you have a leak and looseing boost,you have a leak on your preasure side of the turbo,you can look for black lines And you will find your leak, also all your clamps will torqre to 72 in lbs I hope this helps you and thank you
Posted on Sep 11, 2009
    President:
  • 353 Answers
It is called turbo "whine". This is normal.
If it has just recently started making an odd sound, I would get it checked out. Especially if it is a 6.0L.
Where is the turn signal relay for 2002 f350 2wd diesel at
HI there:
On 2002 Ford Truck F350 Super Duty P/U 4WD 7.3L Turbo Diesel 8cyl the Flasher is located: front seating area, driver side, under dash, mounted in fuse panel.
Hope helps.
Mar 17, 2012 | Cars & Trucks
2006 f350 6.0 powerstroke diesel missing. help
there is no wastegate on a 6.0l turbo. its a variable geometry turbocharger and doesn't need it. i have never seen a turbocharger cause a misfire, the turbocharger is most likely not your problem. if you didn't clean the intake out when replacing the egr valve there is a really good chance that the egr is bad again. also, a bad egr cooler can cause repeat egr failure. also, fuel injector control module is a common cause for misfire
Feb 18, 2012 | 2003 Ford F350 Super Duty DRW SuperCab
I have a 1993 F-350 4X4 with a 351 engine and a C-6 3 speed automatic transmission. The trans does not shift from first to second or from second to third unless you let off of the gas. It also has a...
This is just a guess but the whistling sound you desribe suggests a vacuum leak,such as a split line.If a break is not obvious,lightly spraying the suspect line with ether with the engine running will cause the rpms to go up when you are in the area of the break.Good luck
Feb 27, 2011 | 1993 Ford F350
1994 f350 7.3 idi turbo diesel location of oil pressure sending unit
on the 7.3 idi , the oil pressure sending unit is mounted on the oil tube on top of the turbo. that is if it is the original
Sep 26, 2010 | 1994 Ford F350 Crew Cab
Need to locate flasher (turn signal) on 1999 F350 SD 7.3L
For 1999 Ford Truck F350 Super Duty P/U 4WD 7.3L Turbo Diesel 8cyl the Flasher is located: Behind center of instrument panel.
Hope this help to fint it (remember comment and rated this).
Apr 19, 2010 | 1999 Ford F350 Regular Cab
I have a 94 turbo diesel ford and it sounds like it his a mis
what you need to do is add some sulfur additive to the fuel to build the viscosity rateing and also check the glow plug realy itselfs to make sure when it fires that voltage is actaully getting to the glow plugs
Jan 19, 2010 | 1994 Ford F350 Crew Cab
I have a 2003 ford f350 turbo diesel recently it
Hey man I had the same problem it is the fuel pressure control sensor, you can buy one on ebay for about 100.00 I did and problem solved
Nov 08, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
Fuel leaking from rear of engine under turbo, 7.3
If the engine is running ok it will be a return line,or a leaking injection line,Has your engine been worked on before on the top end if and line has been bent in the past it is proned to leak,I hope this helps
Sep 01, 2009 | 2001 Ford F350 Super Duty SuperCab
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
