Question about LG Heating & Cooling
LG LWHD8000RY6 water leak -- gathers inside on the bottom and by the radiator
  • 615 Answers
This may be due to two things, unclean unit, glugged drain holes…an easy way to do this is to pull the front vent off and see inside and see if you can caulk all around the inside and seal up the front by the vent so the water is forced out the front vent [you need to drill a little hole in the lower section of that front vent after you clean the unit and caulk the inside]
Look to see if the drain holes are clear and the water coming out from them either from the back or the bottom…I am not sure how much work you need to do but you may think about installing a hose to it to drain the water out better than the small hole in the back or front…make sure that the unit is little tilted to the side that you have the vent hole at…
This unit discharge lots of water during heat humidity, etc. or dirt built up on the condensing unit on the back, so cleaning may be with vacuum, water pressure, or just by hand, it is up to you… let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
How to fix water leaking under front of refrigerator
dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
or if it has a water dispenser on the front, try removing the plastic plinth at the bottom of the unit and checking the water connection,
Good luck
Nov 12, 2014 | Whirlpool Refrigerators
Not blowing air through the room but u can feel the cool breeze when u stand infront of it model number lwhd8000ry6
did you check the filter/evaporator coil for clogged filter/no filter clogged coil,is fan turning on inside and out side.
Jul 23, 2011 | LG Heating & Cooling
Water gathers in bottom freezer - thaws and leaks out onto the floor
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | LG LRFC-21755 Bottom Freezer Refrigerator
2002 Chevy impala overheating. Replaced radiator, water pump (thermostat is working properly). Not sure if radiator was bleed out correctly. Car is still overheating and fluid leaking out the bottom...
Engine size? if it has a leak, that is first priority. There may be bleeder screws at the thermostat housing, and the water by pass pipe. just open them slightly until coolant comes out.
Dec 20, 2010 | Chevrolet Impala Cars & Trucks
LG dishwasher leaking out the bottom of the door. It's that gasket that runs along the inside bottom of the door. How do you keep it in place? It keeps pushing in and then floods my kitchen.
My dishwasher was doing the same thing, but it was because of a clogged vent. The minerals in the water built up to a point that it was totally blocked and since it couldnt vent, the water ran down the inside of the door and leaked out the bottom. I just popped the vent cover off of the inside of the door and cleaned it out and it stopped leaking.
Nov 16, 2010 | LG LDF9810ST Built-in Dishwasher
2005 Nissan Frontier transmission fluid leaking into the radiatior.
you have a possible leak inside the bottom tank which the fluid runs through to be cooled before it returns to the transmission.
It is like a little tank inside the bottom tank and if that leaks the fluid will mix with the water.
You will have to have the bottom tank removed to repair the problem or buy another radiator
Jun 09, 2010 | 2005 Nissan Frontier
Rusrty Water leak under steering wheel
if it is your rad some rad weld will give you a temporary fix and tell you if the two things are connected. Rad weld is available from halfords or similar DIY car repair places.
May 28, 2009 | 2000 Mercedes-Benz C-Class
Leak gathering under produce drawers inside kenmore fridge
I can send you a video of that problem if you like. It's a Youtube video.
seabreezehvac@yahoo.com
Feb 28, 2009 | Kenmore Refrigerators
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Heating & Cooling Logo
500 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
