Question about Lands Phones
GHz Cordless Phone
Cordless phone base units circuit does not work. The circuit is burnt within 1 year period of purchase
  • 21 Answers
The base was probably struck by transient current. It will be cheaper to replace the unit with a new one and fit some form of transient suppression on the in coming line
Posted on Sep 11, 2009
How do i program a 6.0 detz phone to a 5.8 cordless base
contact V tech website for technical support but do not think it will work
Apr 02, 2015 | Vtech DECT 6.0 Digital Cordless Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
    Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
    http://www.uniden.com/index/manuals_results.cfm?cat=1
    Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
    Can I connect a CL82409 handset to a CL82409 base system
    Yes, and no.
    When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
    While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
    But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
    However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
    Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
    The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
    Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
    Mar 13, 2011 | AT&T CL82409 Cordless Phone
    I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
    At 20 ft line of sight, you should have perfect reception with most any cordless phone.
    The fuzzy signal can indicate:
    1.
    A weak signal between base and handset.
    20 ft line of sight should have a good strong signal.
    Your handset may be defective.
    Or, your handset battery may be weak.
    Your base unit may be defective.
    2.
    You may be experiencing RFI Interference.
    Is the base unit next to any other electronic devices?
    If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
    I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
    I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
    Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
    My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
    Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
    Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
    Uniden cordless model DC7758-4
    Does the Uniden cordless phone model DC7758 have an answering machine?
    Sep 30, 2008 | Uniden Cordless Phone
    Cordless phone not working
    I am not an expert but sounds like the phone's base unit is damaged electronically (perhaps due to the charger shorting). Doesn't sound like a charger issue.
    Oct 25, 2007 | Panasonic GigaRange KX-TG5432 Cordless...
    Phone Installation - Out Of Service
    Find the manual on the link below. Check batteries are charged preferably for a few hours then perform the reset as per the manual: To re-initialize the handset and base: 1 Disconnect the power to the base. 2 Remove the handset battery pack. 3 Wait at least 15 seconds. 4 Insert the handset battery pack. 5 Connect the power to the base. 6 Put the handset in the base to re-initialize. 7 Wait for handset to display READY (or handset name). http://telephones.att.com/docMgt/public/art/306/2255_.pdf
    Jul 28, 2007 | AT&T 2.4 GHz 2255 Cordless Phone
    HUM
    DSL line. Possible that filters are not plugged in. When DSL service is being used on your line, filters must be installed at every jack that is in use. The DSL signal can cause static/noise, squealing (similar to fax tones) and other issues on your line. (ex. Caller ID problems). In order to avoid having this issue, the service provider gives DSL filters to all customers when they sign up for service. These microfilters must be used because they allow your phones to work properly by blocking the high frequency DSL signals from being transmitted through the telephones. DSL filters should be plugged into EVERY phone jack that has a phone. If you are not using the filters provided by the telephone company, this will cause static/noise and possibly Caller ID issues on your phones that are plugged into jacks without filters. Please contact your service provider for filter information and proper installation. Interference: Other 2.4 GHz products. Other products that use the 2.4 GHz band can interfere with the use of this phone. Items include: Radio towers, pager towers, cell phones, other 2.4GHz cordless phones and 2.4 GHz intercoms or monitors. If any of these items are in the area, they can interfere with the performance of this phone; try relocating the phone. Other 5.8 GHz products. Other products that use the 5.8 GHz band such as home networking (wireless modems) other 5.8 GHz cordless products (phones etc.) can interfere with the use of this phone. Try relocating the phone. Interference from microwave. Microwaves work on the same frequencies as the 2.4 GHz phones. If the unit is on when the microwave is running, it is normal to experience static at that time. Do not plug this phone in the same outlet or near the microwave. Environmental. Normal radio operation. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. Try channing channels. Surge protector or modem. Unplug modem or surge protector that is connected to the unit. Building structure limits range. Relocate telephone base near window when using telephone outside. Base unit located in basement or other low area. Relocate telephone base to higher location. The unit will get better reception if it is not located in a low area. Video displays, television sets and personal computers may cause interference. Video displays, television sets and personal computers can cause interference on this phone. Please relocate the phone to an AC outlet were there is no major appliance plugged in. If the base is near any of the above mentioned, locate the base to another room. Possible telephone line/service problem. Try using your equipment at a different location (i.e. friend or neighbors). If the unit functions properly in the new location, contact your local telephone company for assistance; additional charges to be incurred by customer may apply.
    Feb 11, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
    Lands Phones Logo
    43 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
