Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer a deskjet 3420 printe did not get a cd with it and can not in stall
Norman Al-Anbar
Level 3:
  • Master 630 Answers
  • Posted on Sep 11, 2009
Norman Al-Anbar
Master
Level 3:
Answers
630
Questions
Helped
164810
Points
1759
Go to the site and get a copy of the drivers from download...
1helpful
I have an hp deskjet 3420 printer. How do I connect with this device on mew computer?
According to HP, this printer is not supported in Windows 8. Thus, if you are trying to connect using a Windows 8 PC, there are no drivers that are compatible. You may need a new printer. If you have an older operating system, you get go to the link below, select you operating system, and download the "Driver-Product Installation Software". Run this and follow the instructions top install the printer on your new PC.
HP Deskjet 3420 Color Inkjet Printer Drivers
tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
1helpful
I have an hp deskjet 3420 printer and a Windows 7 laptop. I'm told that I need a 3600 driver as the 3420 driver is unavailable. However I can't seem to find a download for it. Most sites say it is...
Hi, The alternate driver for 3420 is 3600 which is already bundled on windows system, so you just need to add it. Just follow the steps on this link
Please don't rate until follow-up questions have been answered.
Benjoy
How do I add a 3420 desk jet printer to my computer
If your HP Deskjet 3420 Color Inkjet Printer comes with the installation Disk, put the disk into the CD/DVDRom and follow the installation wizard instructions for the installation. You have to attach the USB cable from your printer to your PC USB port. Run the installation disk & power on your printer and your PC will detect & install the drivers & software for your system.
If you do not have the Drivers & Software, download them from :-http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=75040
Be sure to select the correct OS for your download.
Hope it helps.
HI MY NAME IS TOMASINA. MY EMAIL ADDRESS IS [email protected]. I HAVE AN "HP DESKJET 3420"PRINTER.I AM HAVING TROUBLE WITH IT. THE PRINTER ARE ATTATCHED TO MY COMPUTER WHICH IS A COMPAQ FP15 WINDOWS...
hi friend go to
Control panel> Printer and faxes >
double click on your printer (HP deskjet)
there might be pending document's
Now click on printer and click on "cancel all documents"
HP deskjet 3420 won't print in black.
It's probably because the colour cartridge has run out, it needs a colour cartridge aswell to print black.
HP DESKJET 3420
Control Panel
Printers
Add New Printer
Add a local printer
keep as LPT1
Click HP Deskjet 3600 series
Click next
Change name to HP Deskjet 3420
Dont print test page.
Bak to printers
Left click "properties"
Ports
Change to USB
Done:)
k24674
ADMIN Andrew
ADMIN Andrew
