Question about LG Washing Machines
Hi I wonder if you could help I have the L G wm-12311fd I have been having problems with the drainage the washer keeps stopping on O. E. we have had a look in the book and it does not say anything about O.E in fact I think its the wrong book with washer could you please help. thanks Diane
Drain hose is bent or clogged - or - the drain filter is clogged
Posted on Sep 11, 2009
Bosch next 500 series stops mid-cycle
I had a similar problem, after ruling out the following
kink in drainage hose
no blocking of filter
drainage pump ok
ok we eventually found out it was the heater, sounds strange I know as you would not necessarily relate the heater to mid cycle stop an drainage problem....but it sorted ours
ours hope this might help
help regards R
Apr 15, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
Oe error on my lg wm 0642hw ...already cleaned filter, drainage pipe unplugged no luck how do i fix it
http://136.166.4.200/contents/Laundry/WM0742HGA/WM0742HGA_training_manual.pdf
Here is a manufacturers repair service "Training manual" this will help you sort your problem, As you say this is usually, the filter or drain hose. If it is NOT there you may have to suspect the pump, or drive to the pump as suspect. Work through the manual; and I am sure you will sort it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
http://www.repairclinic.com/Washing-Machine-Repair-Help
Apr 17, 2010 | LG WM-1832C Front Load Washer
Machine keeps getting a ue code. i try to redistribute weight, it starts to spin, then stops again. I removed a sock from the drain at bottom left of machine, but still wont work. what next?
You may have to unplug the washer for a few minutes to reset the control...
Too small of a load will also cause balance problems...
Here is a tip that I wrote about that code...
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
heatman101
Apr 11, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
When washing clothes my machine says oe and still has water in it
the OE flashing code means there is a drainage problem.
check hoses for Crimping or Clogging.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Wht does the code OE Mean I can't find my manual for my LG 2077 washer
HI. this code represents a drainage problem. The drain hose may be bent or clogged with debris or, it may be a clogged drain filter as well. I recommend cleaning and straightening the drain hose and i would also clean the drain filter. this should fix the issues you are having with this washer.
please rate and god bless.
Mar 24, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
89 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
