Hi
Thanks for using FixYa. The issue you are facing occurs due to Power supply board failure. You'll need to check the power supply board for swollen capacitors. Also check that the fans are working and there are no loose connections inside the TV. Also make sure the connector cables to and from the power board are firmly connected.
Please remember that the TV contains very high voltages even when it is in OFF condition. So, please make sure that you don't touch any unknown component/ component connections on the board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
I think TV has weak electrolytic capacitors in power supply board that need to replaced with same value. Please check swollen top or leaky electrolytic capacitors in power supply board and replace them all but make sure replacement must be same value (that is capacitance in MF and its working volts) and put them with correct polarity pins (capacitor has plus and minus marks on it)
Thanks.
My vizio tv is not working it slowely stopped working, and now it does not turn on anymore. It slpwely stopped working and was coming on sometimes and other times I had to wait then try turn it on a little later then it sometimes worked but most of the time it didnot turn on.
