Question about Microwave Ovens
The only part working is the light inside.
I have the Maytag MMV5000BAQ Oven with 1600 Watts. The only thing working is the light inside. It was performing fine and the next time I went to use it, several hours later, it was out.
I suspect a fuse is blown but not sure how to remove cover to check.
  • 21 Answers
If the fuse was blown, the light would not come on. The fault could be one of numerous. It is recommended that the appliance is repaired by an expert in this field. As microwave ovens run on very high voltage it is extremly dangerous for a novice.
Posted on Sep 11, 2009
What is the wattage of this microwave mw4720w
The power consumption must be around 1600 watts and the power output is about 1000 watts.
Oct 11, 2011 | Samsung MW4070W / MW4071G Microwave Oven
MICROWAVE IS NOT WORKING IT ACTS LIKE IT HAS NO POWER IF YOU OPEN AND CLOSE THE DOOR DISPLAY WILL LIGHT UP FOR JUST A SECOND
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 21, 2011 | Maytag MMV1163DS Stainless Steel 1000...
I have a maytag microware mmv4203dw works but no heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 12, 2011 | Maytag MMV4203D 1100 Watts Microwave Oven
My Maytag MMV1153BAW Microwave that is only a couple of years old stop working. I changed the fuse (which was blown). It then came on for a fraction of a second and stopped working again. I tried...
There are three micro switches inside the latch assembly. One of these absolutely prevents the possibility of the Magnetron being energized while the door is open. The way it works is if the door is open and the Magnetron is energized, it will act as a direct short circuit and that will blow the fuse. It works very well, unfortunately, that tremendous surge of current ruins the microswitch. Replace the switch. You will find this same information on the instruction sheet inside the cabinet.
Dec 23, 2017 | Maytag MV1153BAW 1000 Watts Microwave Oven
Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Jun 08, 2010 | Maytag MMV4203D Microwave Oven
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Maytag mmv5000baq microwave purchased 2001
Your high voltage transformer probably failed. Good diagnosis!
The economics are your choice, considering age, part prices, replacement cost, etc.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Maytag MMV1153A Microwave Oven
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
