Question about Sceptre X32BV-Naga 32 in. LCD TV
How do i get rid of black spots on the scetpre tv screen
Screen galaxy tab 3 has black lines at top
You can not get rid of them. Take your tablet back to the stores, it has broken pixels, meaning that their are dead spots on your screen or a loose connection.
Mar 10, 2014 | Samsung Tablets & eReaders
There is a black spot on the screen and I don't know how it got there or how to get rid of it...
That Black Spot, is most likely a Dead Pixel, as such there is nothing that can be done to remedy it :( Short of screen replacement.
They can occur spontaneously, the Pixel's "Stick" and will not "Flip" when commanded to, thus you have this black looking "Dot" somewhere on the screen.
Nov 15, 2010 | Polaroid T730 Digital Camera
My plasma tv has blue or black spots (scattered on tv screen) when it is on about 30 mins to 1 hour then as it on for long hours it becomes black spots and covered whole screen
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
May 17, 2010 | Televison & Video
I have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
Oct 30, 2009 | Panasonic PT-44LCX65 Television
Why are there green red blue yellow spots on my tv
it may be display problem...or it can be removed by phosporing screen..
Oct 10, 2009 | Televison & Video
Samsung Tv has sppots on screen when viewing.
Is it a flat panel TV or a picture tube type set?
Sep 21, 2009 | Samsung LN-S4052D Television
Black Spot on Soyo LCD Screen
to get rid of it you will need to replace the screen.
Aug 19, 2009 | Televison & Video
Red spots
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Sep 23, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Dark spots on my JVC 61" tv
dark spot could be a faulty led. if you put a program on that is in white screen you should see all the leds light up the screen. dark spot will be were the led is not working. if on white screen and they all lite up but still dark around the area, it could be the lcd screen. and could be dying pixels. and try this video https://youtu.be/wlA2rcrAOCs
Feb 10, 2018 | Toshiba 55H70 55" Rear Projection...
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sceptre X32BV-Naga 32 in. LCD TV Logo
195 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
