Need help lift gate ajar will not go off
  • 811 Answers
Check electrical switch at lift gate make sure it is making contact and depressed enough to shut off light
Posted on Sep 11, 2009
How to fix door ajar and domelights remain on
You replaced lift gate ,with a used one ? Did you replace door ajar switch with new one ? An what's this ovedrive ? Do you mean overdrive light ? If so the door ajar has nothing to do with that . When that light comes on you have a transmission problem .
Mar 08, 2016 | 2000 Ford Expedition XLT
Why do I see a rear access open and a gate ajar warning on insument panel, even though it is locked?
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post ...
forums.trailvoy.com > ... > 02-09 General Tech Q&A > General
Dec 28, 2009 - 4 posts - ‎2 authors
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post General. ...2002 Chevy TrailBlazer LTZ ... In cold weather, I have a constant "gate ajar" warninguntil the ... Should I try to unhook/rehook the connections to the BCM? ... You might confirm it by starting the vehicle cold, see that you have ... Annoying tailgate ajar won't quit going off on 04 gmc ...
Feb 4, 2010
Rear latch assembly not functioning on Lift Gate
Oct 12, 2009
Gate Ajar - turning off
Jul 1, 2007
passenger door ajar
Nov 9, 2005
More results from forums.trailvoy.com
Rear access door ajar - false signal - Fixya
www.fixya.com/cars/t22610885-rear_access_door_ajar_false_signal
Feb 03, 2016 | 2002 Oldsmobile Bravada
Rear hatch keeps opens while driving...
Unless you have electrical diagnostic skills , I suggest you take this to the dealer ! The lift gate can be opened by operating the switch on the instrument panel. Battery voltage is supplied to the liftgate actuator through the body control module (BCM). The BCM will pulse the lift gate actuator when a release input is received through the key fob, or the instrument panel switch.
The body control module (BCM) receives an input from the liftgate ajar assembly. The ajar assembly is normally open when the liftgate is fully closed. When the liftgate is opened, the ajar assembly contacts close providing a path to ground. The driver information center (DIC) illuminates the rear access open message when the gate is open. The instrument panel cluster (IPC) receives a serial data message from the BCM indicating the liftgate ajar status. If this message is displayed and the vehicle speed is greater than 8 km/h (5 mph), a chime will sound.
It could be ajar switch is bad .
Dec 16, 2015 | 2012 Chevrolet Equinox LS 4dr SUV 2.4L...
Why liftgate acuator clicking when lift gate is open
I would bet on the liftgate module (LGM) It controls all that stuff back there,wiper,defrost,gate ajar light,gate lock and unlock ect. Might try wiggleing the wiring boot where the wires go from the body to the gate,if it changes anything,bet on a broken wire inside that boot.
If not the LGM is my first thought.
Feb 15, 2015 | 2004 GMC Envoy
I wanna know what the wires goin to the release mechanism of my hatch on my 84 dodge ramcharger are
those wires are to the lift gate ajar switch. and lift gate ajar lamp in the dashboard.i hope i was able to help out. THANKS..
Mar 20, 2011 | 1987 Dodge Ramcharger
What is the liftgate?
the liftgate switch needs to be adjusted
or the gate its self.
ps:lift gate is the rear part of your van
G
Jun 24, 2009 | 1998 Ford Windstar
Gate ajar light on Instrument pnl stays on after lift gate is closed and rear cargo lights stay on.??
Need to replace the switch at your cargo door. This will fix both problems!
Jun 11, 2009 | 1996 Buick Roadmaster
Lift gate is closed but still reading ajar. also can't set the alarm because of this.
replace the lift gate/door ajar switches, they are located inside the tail gate on the left and right latch assemblies.
Apr 07, 2009 | 2003 Lincoln Navigator
When driving the vehicle the interior lights flash on and off the power locks flutter and the door ajar chimes.
Check the rear lift gate switch. Or it could be that one of the doors or the rear lift gate is out of adjustment and not closing tightly. Try closing all doors and lift gate then from the outside push in on the doors and see if they go in. If it is the doors , when you push on the one that is causing the problem the door ajar chime will stop .
Feb 19, 2009 | 1997 Plymouth Voyager
LIFTGATE AJAR LIGHTS UP
the problem is the lift-gate ajar/courtesy light switch that is located on the left and right latch assemble of the lift gate, they stick and cause this concern, there are numerous technical service bulletins from Ford about this, have replaced at least 100. PS, washing the engine had nothing to do with it, u can try using spray lube on the latch's and open and close the gate repeatably to see if the switch un-sticks.
Dec 14, 2008 | 2003 Lincoln Navigator
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
