Question about Hitachi 53UDX10B 53" Rear Projection Television
Click...pause pause pause...click...nothing.
There's a click as if the TV is turning on...then a few synchronized ticks...then another click and nothing happens.
It functioned this weekend for about 10 seconds then everything went black and it's been this way ever since. We can't get it to turn on.
Suggestions?
    President:
  • 4,402 Answers
There should be a soldered in fuse in the convergence IC input chain, usually fairly close, if there is an inductor coil in the chain, look for the fuse just upstream of that. Each IC will have a fuse, they look like resistors, but are usually solid color, white, light blue, or light green. Check those for opens.
If you find an open, you can bridge it with a fuse of similar load capability, just to see if the set will power up. If the fuse blows again, look for solder bridges in the IC joints. I know you were careful, but it's really easy to get a bridge, or perhaps overflow the solder to another trace on the board.
In lots of cases, when the IC goes, it takes the fuse with it, and you don't find out until you try to power it up.
Posted on Dec 10, 2007
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
My printer is saying paused and will not print
Hi
If you open Devices and Printers, right click on the menu that comes up and click on "See what's printing", a dialogue box should come up with a list of documents to be printed. In the second column is the status of each document. The first one in the queue will probably say "paused". Highlight this, click on the document menu and remove the tick against "pause" and the printing should restart.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | HP PSC 2355 All-In-One InkJet Printer
My android use my recharged airtime without using it
There are background processes that do this. I'd guess that it's primarily synchronization doing this.
for an unrooted phone (which yours probably is)
In ICS, JB and KK, go to settings / accounts /[probably google] and you will see the account(s) you used to setup your device.
Click your account and you will see a list of services, potentially with boxes ticked to the right. ticked (or checked) means "synchronize". Turn off the ones you don't want. If you want some things just synchronized when you're on wifi (so not using your $$$) check out AutoSync
https://play.google.com/store/apps/details?id=com.redwolf.autosync
Some of your data is also being used by advertisements. Yhe worst offenders are the "push" advertisers who put things on your screen whether the app is running or not. All you can really do us uninstall
for a rooted phone:
install afwall+.
https://play.google.com/store/apps/details?id=dev.ukanth.ufirewall
You can set per-application internet permissions (wifi, 3/4g, roaming). Not just synchronization - everything.
May 12, 2014 | Cell Phones
Sanyo Clicking/Ticking Sound
That is caused by the insulation on the EHT cable or tripler leaking.
Jun 12, 2017 | Televison & Video
Tv will turn on and click off a few minutes later
look to see if power light blinks in a sequence, like three blinks pause or five blinks pause,this will point to the problem.
Let me know what you find.
Steve
Oct 10, 2011 | Panasonic PT-47WX49 47" Rear Projection...
2002 Ford Taurus has no power. No head lights no dome light no horn blah blah. Ok first of all my cars alarm kept going off by itself off and on for 2 weeks. I come out to start the car and it goes click...
One possibility is that the battery terminals are either corroded or not tight to the battery posts. Second, the battery itself may have seen its days. Try another battery of simply replace it. If the problem still exists, the have a mechanic inspect the main wiring from the battery to fuse block. Your alarm device may have its own battery source. The tick tick are the cars systems relays trying to engage, but there is not enough power for them to engage.
Aug 18, 2009 | 2002 Ford Taurus
I have a deskjet F300 HP
Goto Start > Printers and Faxes.
See whether your printer is set as the default printer. (Default printer icon has a tick mark next to it).
Double-click the printer icon.
You will see a list of documents pending. Delete all the files. (Or select an item, and from document menu, click cancel. Do this for all the items).
Close this window.
Right-click the printer icon and see whether 'Pause printing' is ticked. If so, click it to remove the tick mark.
Restart the printer and the computer. (This is optional, but better to do it).
Now it will be OK.
Aug 12, 2009 | Office Equipment & Supplies
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
Why doesn't my conduit save my synchronization preferences?
you should set these conduits to default. when you change these conduits to do nothing you notice a checkbox on the right potion of the window labeled 'Set as default' tick on that and click on ok.
Sep 11, 2005 | Palm Treo 650 Handheld
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
