Question about Elizabethan Classics Basin Taps - Lettered Porcelain Lever Handles
Water is getting through the bottom of the tap as the tap hole is not perfectly flat. The plumber said it was my tap but i exchanged the tap but clearly they do not sit flat on the basin. Help!
  • 21 Answers
When you fitted the tap, did you put a layer of putty around the base of the tap? This should be done to seal the base and water will not leak past
Posted on Sep 11, 2009
Junior 24i intermittent hot water heating works fine and the green light comes on when turn hot water tap but water cold
sounds like you need a plumber many tanks have an internal pipe that sends the cold water to the bottom of tank called a DIP tube plastic and they fail
Feb 23, 2015 | Water Water Heaters
Does anyone have installation instructions fo a Bosch free standing dishwasher smu50E65au? Thanks. Julie
Hi Julie.
A dishwasher needs access to water numerous times during it's cycle. You'll have to have the hose on the tap with water pressure on while the machine is in operation. You could exchange your tap for one with thread or install a second one behind the current one.
(Slightly agricultural repair)
When installing a dishwasher the drain hose outlet MUST be above the water level in the machine or the water will run out as soon as it is put in...They usually connect to the S bend under the sink.
It would probably be best to have a handyman/plumber attend to the job.
Good luck
Nomess
Jan 31, 2015 | Bosch Washing Machines
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
How do I stop shower taps from leaking
remove fawcet handle take out the cartride and replace the rubber oring and bevelled or flat rubber washer on end make sure to shut off water supply first if cartridge is in bad shape buy a new replacement one at hardware or plumbing store reinstall
Dec 12, 2012 | Sterling Plumbing Home
My Alpha 240E boiler does not heat water from the taps unless the radiators are on. I have been told this is because my boiler needs a new convertor valve, can I purchase a convertor valve and how wou
Its a diverter valve thats required not a converter as you state,it is not recomended to do it yourself ,you can get the valve easily from a reputable plumbers merchant ,alpha is a popular boiler, just supply the gas control no or boiler details to the merchant and the should be able to get the right divertor valve, then you just have to find a good plumber to fit it , it would be quicker and safer for some one qualified to change this.
May 19, 2017 | Water Heaters
I have a water leak that is coming from the bottom of motor seems like it is coming out by the oil pan towards the top, what is the cause of water leak? as sonn as i pour in water into radiator it leaks...
Look for a leaking freeze plug. That is a circular disk of metal that is inserted at several locations in the lower half of the engine block, usually. You may have to remove other parts to expose it adequately. It can be removed by tapping one side of it with a hammer and driving one side in, causing it to swivel in the hole, then pry it out. Get a replacement of the correct diameter from your auto parts store, and tap it back into the hole, first making sure the hole is clean a smooth. Be careful to tap all sides of the disk evenly, sometimes it is cup shaped. Tapping on a flat piece of metal covering the whole disk will sometimes be of help in keeping the plug straight in the hole.
The other possibility would be a crack in the engine block. That would require a replacement engine.
Mar 02, 2011 | 1991 Dodge Dakota
How can you fix a moving base of a tap on a sink, tried tighten it and still did not work.
Is it a conventional tap with the 3 pipes or just the one hole in the middle with a cover for the other holes in a replacement? Are the nuts on the bottom of the pipes? To tighten it up? Or did the plumber just put on the supply lines and hope that would work?? Check it out, I made a wrench out of a piece of 1 inch pvc schedule 80, cut a slot with the band saw on one side about 4 inches for the supply line, then cut out the other side about 1 inch for the wing on the nut. It worked perfect. I couldn't get up there to replace the faucet, and that wrench with the T-handle didn't do diddly. Check it out, see what he did under there and tighten it up. Hope this helps.
May 04, 2010 | Plumbing
Baxi duotec is heating radiators but not tap water? Has been deteriorating for weeks. needs TWO taps turned on to get hot from one! powerflush help? been told its sludge in heat exchanger?
Sludge / furring possible in primary part but not if the ch & flow through hot tap are ok More likely it's the diverter valve. The rubber diaphragm inside is perished / holed. Replace
Oct 27, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Elizabethan Classics Basin Taps - Lettered Porcelain Lever Handles Logo
57 people viewed this question
Top Elizabethan Classics Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an Elizabethan Classics Plumbing Expert? Answer questions, earn points and help others
