Question about Mozilla Firefox
Why are my Plug-ins blocked? - Mozilla Firefox
  • Mozilla Master
  • 8,046 Answers
If they are installed, you must enable them.
Open Firefox Click Tools-->> Extensions. Click Tab Plugings. The list of available plugins will show: Select each plugin. If a button appears on the same line that says Enable, Click the Enable button. Do that for every plugin in the list. Click the X at the top right of the Pluging window.
Hope it helps.
Posted on Sep 11, 2009
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
How to install block heater on 97 chevy tahoe
The frost plugs that block heaters go in are along the sides of the engine block. About midway up from the bottom of block where the oil pan mates to the top block deck. 3 or 4 on each side, 1 to 2 inch diameter round metal plugs just slightly recessed in the block. Look below the exhaust manifold, behind the exhaust pipe on the block. Frost plugs are easy to punch out as long as you can get to them.
Punch in one side, and the other side will start to come out-then grab with pliers or vice grips to remove the plug.
When you buy a block heater for your Tahoe, it will come with an instruction sheet, and a diagram of the preferred or recommended frost plug hole to use the heater in. It will also usually show the positioning of the heater element in the block-how to orient the heater into the opening so the element does not touch the block anywhere, but is placed in so the element is exposed in the water jacket of the engine. That make sense? You do not need a sealer, as the block heater has its own O-ring rubber seal. When inserted and tightened down (small wrench or socket, about 3/8 inch or smaller size, do not over tighten-follow sheet instructions), the o-ring should not leak. Be sure and clean that recess well that frost plug was in- get all the rust and scale off with rags or emery cloth (sandpaper).
Not hard at all to install a block heater once the frost plug is removed. Getting access to the frost plug is the devil to deal with. If you are unsure, have it installed for you.
Jan 06, 2014 | 1997 Chevrolet Tahoe
The block heater cord to 2004 jetta came unplugged from the car and I'm not sure where to look to plug it back in Can someone give me a general idea where it might go?
Block heaters are installed on the engine block in one of the "freeze plug" openings. The freeze plug is punched out and the block heater is installed in its place. The freeze plugs, about 3 on each side of the engine, are midway up the block- a round, slightly recessed metal plug about 2 inches in diameter that is driven into these holes made during the engine casting process. The freeze plugs will be found below where the exhaust manifold attaches-so if you are looking on the side of the engine with the exhaust manifold-look behind and just below the exhaust manifold. The other side of engine will have the same number of freeze plugs at the same level on the engine block.
Your block heater is probably on the front facing side of the engine (towards the radiator). It is probably shinier than tom the he regular freeze plugs, will have a small screw in the center for tightening when installed, and will have 2 or 3 metal prongs that your heater cord attaches to. Simply plug it back into the heater. Just remember: about halfway up on the engine block, from the oil pan rail at bottom to the top of block where the cylinder head mates.
Dec 13, 2013 | Cars & Trucks
Under the car it looseing antifreeze a freez plug is how to replace and want look like. 2002 chrysle concorde with 2.7
Your motor has several freeze plugs. The freeze plug holes are located usually 3 per side on the block, 2 in the ends of each head and 2 in each end of the block. Determine approximately what location the coolant is running out from, feel around the block for an actual round hole/cavity in the block. They are different sizes. some as small as 1 inch diameter to as large as about 3 inch diameter. Find the cavity that is not filled, as you can stick your finger deep into the block/head.
Then measure this hole. The easiest type relacement plug is called an expansion type. It is like a rubber stopper that you tighten a bolt in the center of it to expand it/tighten it to the full diameter sealing the cavity. Found at most parts stores. They come in a variety of sizes, so you must try to get extremely close to the actual diamerter of the freeze plug hole in the block/head to make it work. Install new plug into hole pushing rubber portion in all the way until the flat metal washer part of the expansion plug contacts the block/head surface. IT MUST be flush or evenly seated in the freeze plug hole/cavity in the block/head. Tighten center nut on new plug to about 25 ft lbs. This will make the rubber part expand and seal into the hole. Refill coolant, check for leaks. In my experience, if you pop one plug, it is usually in the block first and one will be popped on both sides of the block. Feel around BOTH sides of block to verify all 6 plugs are in place! CAUSE>>
This is due to water in the coolant system freezing, due to poor coolant system maintenance. The freeze plugs pop out when the frozen water expands preventing the freezing water from cracking your block.You would be money ahead to drain/flush your system and refill with all new 50/50 antifreeze of the type recommended for your vehicle. NEVER put water in your cooling system! Use only in emergency, fix problem then drain and refill with 50/50 coolant! This will prevent this problem from reoccurring and damaging other cooling system components.
Jun 06, 2011 | 2002 Chrysler Concorde
1992 Saturn SL1/ Where's the plug in for the block heater?
If it has a block heater the plug should be in the front under the grill. 3 prong regular household plug.
Feb 25, 2011 | 1992 Saturn SL
I am looking for the location of the block heater plug on a 1997 Golf diesel, thanks
There is no specific spot for a block heater. A block heater can be in any location the block currently has a freeze plug in. You'll need to look over the block carefully - you will see several round "ports" on the block and one of them will have a wire coming out of it. A freeze plug looks kind of like a small dish in the block, whereas a block heater will look more like a flat plug with a wire. It could be on the side or back of your motor - rarely is there room for a block heater on the front of a motor. Look in the front grill or in the general area of the radiator and you should see one end of a male electric cord( like the end of a lamp cord you stick in the wall ) . Follow this wire to the engine and it will lead you to the location of the block heater. You will probably need an inspection mirror and a flashlight to find the other end ( in the block).
Hope this helps!
Nov 22, 2010 | Volkswagen Golf Cars & Trucks
Were is the drain plug located on a 2007 chevy 5.3 on the passenger side of engine . is it behind the ac unit. i want to put a engine block heater in.
The block drain is on the passenger side of the engine, in the center of the block near where the oil pan attatches to the block.
Engine Block Plugs/Sensors
100 - Engine Block
100 - Engine Block
101 - Oil Gallery Plug - Front
110 - O-Ring
111 - Oil Gallery Plug - Rear
112 - Oil Gallery Plug - Side
113 - Washer
114 - Engine Coolant Heater
115 - Washer
116 - Oil Gallery Plug - Side
117 - Washer
130 - Transmission Housing Locating Pin
145 - Washer
146 - Engine Block Coolant Drain Hole Plug
701 - Crankshaft Position (CKP) Sensor
702 - O-Ring
718 - Knock Sensor
718 - Knock Sensor
739 - Bolt
739 - Bolt
750 - CKP Sensor Bolt
Oct 19, 2010 | Chevrolet Silverado 1500 Cars & Trucks
How to install a block heater on a chevy trailblazer?
First check and see if there is a pouch located directly beside your battery. If there is a pouch it will contain a plug that is for the factory engine block heater. If there is no plug then you can pursue an aftermarket type.
There are several types. If you want to use a freeze plug block heater, you'll need to have someone help you remove a freeze plug. That usually requires that you remove a lot of the peripheral equipment until you can get a clear access to one of the freeze plugs. Measure the freeze plug then go to an auto parts store and purchase a freeze plug block heater of that specific size. Once you have one that will fit into the hole, you can drill a hole in the freeze plug, then use a prying instrument to remove the old freeze plug. The block heater freeze plug usually goes in with a nut to tighten the freeze plug into the hole.
BTW, you'll get a lot of antifreeze all over when you do this, and plan on taking your time since it will be time consuming.
Jan 02, 2010 | 2005 Chevrolet TrailBlazer
Where can i find the plug from my block heater in my 1997 chevs10
not all s-10 came with a block heater. the plug is on the end of a long extension cable, should be on either side of the block. if you can't find it, it most likely doesn't have one. you can install one, just by the kit from your local GM parts department, raise the vehicle in the air, remove a freeze plug & install the block heater where the freeze plug was.
its not an easy job.
Dec 31, 2009 | 1997 Chevrolet S-10 Pickup
1992 ford f-150 flareside coolant leak back of block
The blocks ususally have a petcock type drain plug on the sides. Check for those, they may have gone cheap and simply put a brass plug in the hole...usually mid block below the cylinder heads.
May 08, 2009 | 1992 Ford F150 SuperCab
Mozilla Firefox Logo
62 people viewed this question
Top Mozilla Computers & Internet Experts
k24674
Alun Cox
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
