Question about VeriFone OMNI 3200 (P092-101-10) Printer
Terminal frozen - VeriFone OMNI 3200 (P092-101-10) Printer
  • VeriFone Master
  • 13,433 Answers
Only thing I can suggest here is to unplug the power from the terminal for a minute and plug it back in and see if it works after that.
Posted on Sep 11, 2009
Flywheel frozen
1) test the input voltage terminal Motor, and see if there ARE voltage see my personal TIPS for help. if there are voltage and the motor NOT running the motor is faulty.
2) However you must test the output voltage control board for input voltage terminal motor, if there ARE NOT the board is faulty.
God bless you
Nov 13, 2013 | Exercise & Fitness
Defrost Problem - evaporator completely frozen
i know i think in the fridge part (atleast on mine) there is a knob for temp.
if that doesnt work i guess you need another defrost terminator
Dec 13, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Screen has frozen Casio qt 6600
flag clear the till, and try again,
if it is a long report the till will stop and then start
flag clear power off the till on the side
hold the button down at the front
power on the till
press the ok button
then after 30 sec to 3 min
press yes
Feb 09, 2013 | Casio QT-6600 Cash Register Touchscreen...
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be...
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
Jul 16, 2010 | Amana Refrigerators
I have some frost forming in the freezer and it seems to be running all the time. I have cleaned the condensor coils and that did not help.
the self defrost system has a problem. 3 componets in that...timer/control, heater, terminator....1 of those has gone out. start with heater, should have continuity as should the terminator (when frozen)..timer is usually hard to check witout instraments..if heater and terminator are ok, replace timer/controller.
Oct 25, 2009 | Amana ABB1927DE Bottom Freezer...
Fix the fatal error in my warcraft 3 frozen throne
This application has encounter a critical error:
FATAL ERROR!
Program: F:\games\lan games\warcraft 1.24.1.6374\war3.exe Exception 0xC0000005(ACCESS_VIOLATION) at 001B:15019B9E
The instruction at '0x15019B9E' referenced at '0x57746E65' Ther memory could not be 'read'
Press OK to terminate application.
Then:
Frozen Throne was unable to locate your CD-ROM drive. Please make sure your Frozen Throne disc is in your CD-ROM drive, then click on 'Retry'.
Oct 22, 2009 | Blizzard Entertainment WarCraft III: The...
No water or ice
HI. could be4 as simple as a frozen inlet line or, the water inlet assembly valve may be damaged as well. I recommend inspecting the lines for ice or frozen water. if the line are Ok and not frozen, this will confrim a defective inlet valve.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Aug 17, 2009 | Refrigerators
GE side by side. defrost heater does not come on. Installed new heater, no luck.
When the timer turns off the compresor to defrost it sends power to the defrost terminator (round thing atach to the freezer coil ) who energized the heaters if the coil is frozen ,at this time you can check if there's power to the terminator ,if not timer is bad, and if the timer sends power to the terminator and it won't close when coil is frozen up the terminator is bad.
Aug 13, 2009 | GE Refrigerators
Freezer will not auto defrost , coils icebound
The problem is in the defrost timer , heaters or the defrost terminator ,most of the cases is in the timer you can turn it until the compresor off and if the coil is frozen the heaters will came on if this happend the timer is bad but if the freezer coil is frozen and after you turn the timer to the point that the compresor goes off and the heaters won't kick on it means that the heaters are bad or the defrost terminator fail .YOU can check the heaters for continuity and replace the one thats open or you can buy the deefrost kit which came with the heaters and the deefrost terminator.
Apr 18, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
VeriFone OMNI 3200 (P092-101-10) Printer Logo
160 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
