Question about Frigidaire ATF6000ES Front Load Washer
Front loader, will not spin at high speed drain
Front loader, will not spin at high speed, drain pump appears to be working but clothes stiil wet
    Problem Solver:
  • 14 Answers
Drain strainer on output side of pump could be clogged a little.
Posted on Sep 11, 2009
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
GE Front Loader Won't complete cycle
My GE Front Loader is 18M old and it has been progressively getting worse, not spinning the water out......I should have known the Pump had a cleanable strainer as Solution #1 says. Pulled a fist size chunk of wet lint, coins, a necklace and wrappers from the Strainer, not to mention about 2 Gal of dingy, soapy water. Tried a Drain/Spin and after a couple of minutes, went to High Speed Spin for the 1st time in about 3 months. Obviously there is a Water Sensor on the Drain Line somewhere that if the Drain Line still has water in it, it does not allow washer to go into Med/High Spin Mode.
Jan 14, 2009 | GE WSXH208A Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Frigidaire ATF6000ES Front Load Washer Logo
216 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
