Question about Air Tools & Compressors
Need exploded view of Husky Pro HVLP HDS890....
I need exploded view of Husky Pro HVLP HDS890.... The air flow valve leaks air out by the trigger. Have changed o rings but still not working right.
  • SIMPSON May 29, 2013
    HOW DO I DOWNLOAD EXPLOAD VIEW
  • 3 Answers
The gun was made by Campbell Hausfeld. I had the same issue when it was new. The shipped me the parts free of charge. The below link will take you to what you need. I realize this is a late post, but others may need it as well.
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=hds890
Posted on May 02, 2010
  • 3,600 Answers
Here is the site where you can get the right parts and the diagram to help you with fixing the problem if you need help I can give it to you but you seem t be mechanicaaly inclined so figure all you need is the diagram and parts info. http://www.homedepot.com/Paint-Paint-Sprayers/h_d1/N-5yc1vZ1xr5Zarv5/R-100668721/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
please rate if this was helpful.
Posted on Sep 13, 2009
  • Bruce Hathcock Sep 14, 2009
    If it is comming out of the trigger you need to check the pental shaft for the air adjustmet rod in it hasa slight indetatation on the rod you will have to replace the rod, I have had this problem on all air gus I have owwned. If you don't see a wear spot on the rod post to this comment and I will get back to you.
  • JOHN LAPIER May 05, 2011
    This is a two year old post i have the same gun and am a comerical spray painter i got the gun from my father as a gift and he owenes a comerical paint co . The problem is there is no gasket at the neddle this is why it leaks and this correates an air leak that makes the gun surge .The olny thing to do is make a gasket but its a cheap gun and for limited use at best
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
Craftsman 18 gauge braid nailer wont fire. Just hear and feel air escaping near trigger mechanism.
18 gauge nailer. Not cars! Anyway check inside the housing bad either replace or disassemble the mechanism (trigger valve) clean everything better to replace and grease it liberally before reinstalling. The o rings tend to roll or flip causing binding ( leaking) sometimes you can take off the back housing where the air goes in and look in the back to see if its sealing correctly. I played with mine for 2 hours. Before I called a service guy at Thomas industrial supply got there number off the web. They helped me a ton for free got somebody right away. Nice folks. Very knowledgeable. Got me up and running am smarter for the whole experience.
Jan 17, 2015 | Cars & Trucks
My husky framing nailer leaks air around trigger
Leak around trigger could be trigger valve internal orings or orings on the outside of the trigger valve making contact against the body of the gun. Spray soapy water to determine where the air is leaking from. If air is leaking around the outside of the valve, most likely the orings were cut upon installation of the valve. If leaking from internal valve, most likely worn or broken oring; easy to fix if you have a source for orings.
To remove the trigger valve for service or inspection (take close-up photo of trigger area for reference ):
disconnect airline, remove nails, remove trigger retainer pin, remove trigger, remove roll pin /s holding trigger valve in place (use 3mm punch to remove retainer roll pins which are located in the body of the gun just above the trigger valve). With retainer pin/s removed and with gloved hand (under trigger valve), apply air pressure to gun to blow out the trigger valve (use lower pressure to push out trigger valve because it could come out with force.). With trigger valve in hand notice that there are two slots or groove cut neer top of the valve where the retainer pins rest, you will need to reinstall valve into body with slots aligned to retainer pins. Remove retainer pins holding trigger together to pull out internal valve. Good luck and post again if your have other question about the trigger valve.
Nov 15, 2012 | Air Tools & Compressors
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
I have a N-60 finish nail gun. It is leaking from the trigger and it is trying to fire a nail and discharges the rod to drive the nails and the rod stops and will not retract. I think I need to purchase...
the trigger valve could be causing a lot of your problems, you are correct in ordering the o rings and trigger valve, make sure to lightly coat the o rings before installl. If you have trouble with the valve I have detailed instructions in the TIP section on how to remove safely.
Aug 15, 2011 | Stanley Bostitch Nail Gun
Where can I find an illustrated parts breakdown for a vaper hvlp spray gun
mine came with a one page manual with exploded views of the guns with numbered and named parts on the back.
Nov 10, 2009 | Vaper Titan 3 Pc Hvlp Dual Setup Spray...
I tried to adjust the regulator and the back just screwed off of the body - any ideas on how to prevent that?
Possibly you were trying to adjust the regulator without having air flowing through it. You must squeeze the trigger on the gun and have air constantly flowing through it otherwise the regulator knob is very hard to turn against the pressure inside it. To set an accurate pressure, squeeze gun trigger (while connected to air hose) to get air flowing... then twist regulator knob out (or in the "-" direction) until air flow reads 0 on the regulator gauge. Then start twisting regulator knob the other way until you reach the desired pressure on the regulator gauge. Also make sure the regulator is attached with air flowing the correct way through it. There should be an arrow somewhere on the regulator body which should be pointing toward your spray gun.
Oct 05, 2009 | HVLP 2.5mm Hvlp Spray Gun-auto Paint...
I DESPERATLY NEED A DIAGRAM OR EXPLODED VIEW OF THE TRIGGER MECHANISM OF THE IMPACT WRENCH AS SOMETHING IS MISSING IN MINE. IT HAS NO TRIGGER CONTROL AN RUNS CONTINUOUSLY IN BOTH DIRECTIONS.
take it to a servce centre for air tools ,there is a little neoprene or plasic o ring right up in trigger area ,that gets brittle and starts to break up. bugger of a job, why waste aday they wll do it in a flash (sort of) youdoit
Aug 04, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Where is the o-ring for the air intake
The problem is in the trigger valve and is a very common problem with these and other brand, some even do that when new! Most people just live with it but you can dissassemble the gun and try.
Jun 21, 2009 | Impact Husky® 1/2" Wrench
Air Tools & Compressors Logo
2,863 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
