Question about Cell Phones
Samsung e800 switching on button....
How long do i hold the power button to switch the mobile on?
Samsung forgot phone pattern
You can remove your lock by a hard reset. This procedure will erase your personal data like accounts, other passwords and etc.
- Switch off the tablet. (To force shut down, pres and hold the Power button more time).
- Press and hold the Power and the Volume Up keys.
- When you see the Samsung logo, release only the Power key.
- Use the Volume Up/Down keys for scrolling and the Power key for OK.
wipe data/factory reset
Yes -- delete all user data
reboot system now.
This procedure is same for Galaxy Tab 2.
Aug 06, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Tip
How to format Nokia N72, N73, N80, N81, N95, NSeries Phones
<span> <p>Nokia Became the Most Admired Mobile Phone Manufacturer and Most of the World mobile phone users have <a href="http://www.messiphone.com/mobile-secret/nokia.html">Nokia phones</a><br />But some models are more popular than others like N72, N73, N80, N81, <a href="http://www.messiphone.com/mobile-secret/nokia-n95.html">N95</a> and NSeries. <br />To fix some problems ( eg : get infected with virus, some system errors or installed too much software on it), many users asking me how to format Nokia NSeries Phone</b>.<br /> <p>So here are 3 ways method to format your Nokia NSeries cell phones<br /> <p><br /> <p><span> <p>Method 1<br /> <p>1. Turn off the mobile Phone.<br />2. Press and Hold the following three buttons: Green Call Answer button</b> + the "*" button</b> + number "3&prime; button</b>.<br />3. While holding these buttons, press the power button</b> and switch on the phone.</b><br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons</b>.<br /> <p>Method 2<br /> <p>1. Switch off your Noki</b>a mobile phone<br />2. Now Press following key sequence *#7370#</b><br />3. Enter Default lock code is 12345</b>.<br />4. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />5. Wait for message 'Formatting</b>' to appear on the screen and release all keys once you see that message.<br /> <p><span> <p>Method 3<br /> <p>1. Switch off</b> the phone.<br />2. Hold down *#7780#</b> button.<br />3. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons.<br /></span><br /></span><br /></span>
on Jan 11, 2011 | Nokia N73 Cellular Phone
Tip
HARD RESET Toshiba e310 e330 e335 e350 e355 e400 e405 e570 e740 e750 ...
Make sure your device is off before performing hard reset. While holding the power button press in on the reset switch with your stylus then release the power button. When a screen appears release the reset switch.
on Mar 10, 2010 | Cell Phones
How to format sg-b130s
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
Nov 06, 2012 | Samsung SGH-E251 Mobile Phone - Black
Switch off mobile after switch on not working then go to recovery mode
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Oct 09, 2012 | Samsung Cell Phones
I want restore own mobile but my mobile need lock coad
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Dec 11, 2010 | Nokia 6600
How to format the nokia n81
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
Sep 04, 2010 | Nokia N81 Smartphone
My mobile SGH_E800 Is having camera problem. when i switch on to camera mode a hazzy picture is displayed on the screen.
Feb 11, 2010 | Samsung SGH-E800 Cellular Phone
E800
Hello
E800 means : E800 Auto power off circuit problem. Main switch or DC controller
Feb 08, 2009 | Canon NP 6050 Copier
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
