Question about Acer AL1916W 19" LCD Monitor
Acer monitor screen repeatedly blinking off and making ''popping'' sound
  • 60 Answers
IF you are seeing any kind of spark at the same time it needs to be unplugged and taken to a reapir person. Chances are it's done though.
Chers
Al
Posted on Sep 11, 2009
Acer X163w monitor auto adjust keeps popping up
Check to see if you have any dust, or grim by the buttons. I cant recall if this monitor's buttons are touch sensitive or not, but a good cleaning to make sure they are not stuck should clear the issue right up for you!
Aug 31, 2012 | Acer X163w Computer Monitors
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
At the desk top, I moved the mouse to begin and the screen went black. All it gives is a blinking orange light. Pressing the switch doesn't matter. Upon rebooting , blinking light persists while you can...
Sounds as though you have a backlight issue. How old is the monitor?
The keyhole with the lock sign is for a security lock to lock the monitor to a desk so it cannot be stolen.
Mar 08, 2011 | Acer AL1916W 19" LCD Monitor
Acer CRT ac501 Monitor resoloution Problem The Picture Is Wider Than The screen How Do I make it Smaller??? I try To Adjust The Picture But No Result
Hi, this sound like you have a (Resolution) problem. First; (right) click on an empty area of your Desktop Screen, next click Personalize; click Display Settings from here you can adjust the resolution of your screen. You can repeat these steps until you are satisfied with the results. Thanks paul7of9
Jan 13, 2010 | Acer AC 501 15" CRT Monitor
My son had this problem with his Acer Aspire making a popping sound and the screen going blank, What do we do to solve this problem? Acer Aspire 5315-2077 Thank you for any assistant.
Does the popping sound seem to come from the bottom of the screen, near the middle, or just above the keyboard, in the middle? If so, the inverter board (which takes battery voltage and bumps it up to voltage high enough to run the display backlight) could be shorting out. If you connect an external monitor, and THAT keeps working, then my suggestion might be correct. The inverter board is not expensive, but the labor to replace it is.
Mar 03, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
Monitor turns off
Since the green light is going out the monitor's power supply could be the culprit. That popping sound is not good. I would replace the monitor all together.
Jun 03, 2017 | Acer AL1715 (Black, Silver) 17" LCD...
Popping noise and blinking screen
It's a good thing it isn't a CRT monitor. I would have suggested getting rid of it before you get yourself hurt.
Spraying air in it sounds like a good idea. Make sure the monitor is off when you do it.
Good luck.
Jul 26, 2008 | Acer Computers & Internet
Static or popping sound
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jul 24, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Acer AL1916W 19" LCD Monitor Logo
269 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
