Question about Frigidaire ATF6000ES Front Load Washer
High spin cyclewil not work
Won't spin at high speed mod ltf2940eeo
    Problem Solver:
  • 14 Answers
Just had mine repaired. ended up being the strainer before the pump was clogged. Hope that helps
Posted on Sep 11, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
My washing machine won't go to high speed spin to remove water from clothes.
Possible there is no switching for the cycle from the controller or there is speed limited due to sensor action for vibration. Check the leveling of the machine, if not use rubber footing to hold the machine steady.
Also check the drives for friction , if so reset and lubricate.
Jan 21, 2013 | Washing Machines
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Machine will not spin
If the machine washes but won't go into the high speed spin, then either the speed control board is bad or the door switch is bad. Look in the machine there is a tech document to help you with this problem.
Nov 03, 2012 | GE WPXH214A Front Load Washer
Maytag neptune washer won't high speed spin
Try either capacitor or motor brushes. Your voltage isn't quite high enough or it's not getting through
May 19, 2012 | Washing Machines
My toshiba mod. 52hm95 lamp cooling fan is making noise and i am having trouble locating a replacement
Fan like noise may be a fan or the color wheel---color wheel spins at high speed(lamp faces it) and when failing you will have a high pitched or fan like sound---hard failure and you will hear a grinding sound.
May 16, 2012 | Televison & Video
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
No high speed spin
could be the door latch, there is a wax motor in it that closes just for the high spin, if the computer (board) doesnt get that signal it won't go into high spin
Mar 06, 2011 | Frigidaire GLTF1240A Front Load Washer
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
When on its final spin cycle washer does not spin at its normal high speed. it is three weeks out of warranty! I can't see anything mechanically wrong, so i'm assuming it has a self destruct program! Will...
REPLACING THE CIRCUIT BOARD SHOULD BE YOUR LAST RESORT.YOU NEED TO CHECK THE MOTOR WINDINGS ON THE MAIN MOTOR IF THEY OK THAT CAN ALSO CAUSE THE MOTOR NOT TO SPIN TO ITS FULLEST ALSO CHECK YOUR CAPACITOR IS OK.GOODLUCK. MOAHMED
Sep 11, 2008 | Whirlpool Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
