Question about Electrical Supplies
Honda Em6500 generator won't generate. Did the plug a drill into it and spin the drill chuck by hand. Started working but when i started it up recently, same problem and drill trick won't work. How do I remagnetize it? It's not an invertor generator but a brush type
You need to locate the the brushes and check to be sure the brushes are good. Then use a 6 or 12 volt battery to the proper pole on the brushes just for a few seconds. NOTE this can be Dangerous as you are using electricity and you have moving parts near where you will be working. Then try to see if it works Your winding may be shorted or open.
Posted on Sep 24, 2009
What size capacitor do I need for my 5250 power back brushless generator r
Why do you assume you need a new capacitor? Sometimes you may have to re-excite the windings on the generator which is simple and I'd try it first. Take a power drill, plug it into the panel on your generator and turn the chuck on the drill by hand or use another cordless drill to spin the plugged in drill for about 5-10 seconds. Unplug the drill and start your generator. Chances are you'll produce the power you are looking for.
Jul 20, 2017 | Electrical Supplies
No 110 voltage
Check the circuit breakers for a tripped one. If all OK, then the brushes may need to be replaced. Here's a tip on how to flash the field in the generator: This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
  • Plug the electric drill into the generator receptacle. (Cordless drills do not work)
  • If the drill is reversible, move the direction switch to the forward position.
  • Start the generator
  • While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
Use caution not to get your hand or other materials caught in the chuck. As soon as the field is excited, the generator will produce power and the drill will turn on.
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor windings, which is fed back through the trigger, cord and into the generators receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field, which is intensified due to the iron core of the stator laminations. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed
Aug 11, 2016 | Electrical Supplies
Generator is running perfectly but wont put out any power?
Hello, you will need to Flash the Field. With the generator running, plug a drill motor into one of the 110 volt recepticles. Now for the DANGEROUS part. Pull the trigger on the drill.........now with the other hand..........Quickly spin the chuck. DONT hang on to the chuck. The drill should start to run. ..Your done. If it doesnt work, spin the chuck the other way. This polerizes the stator and will work.
BE CARFULL.
Happy Generating!
Let me know how it goes, Thanks
Jul 28, 2011 | Garden
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
How to flash or remagnitize Coleman Powermate 6875 or Husky 40500
Field Flashing of Portable Generators This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed - Bruce Perrault
Apr 27, 2010 | Coleman Powermate Powermate 5000W...
No high voltage output
If you can't get power to flow once generator starts, try this...
Look in the manual. There is likely something about field flashing the magnetic field2.gif. According to the Briggs and Straton web site (similar solution for all generators), the easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Nov 17, 2009 | Coleman Electrical Supplies
My craftsman generator model # 580.32672 starts but will not put out any power ive tried a few suggestions but nothing has worked
Look in the manual. There is likely something about field flashing the magnetic field. According to the Briggs and Straton web site, the easiest way to do this is to.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
Generator starts with and runs great, but theres no current on my toy hauler
Johnny,
If generators are not used regularly, they need the their magnetic field to be charged (or flashed). This can be done by plugging an electric motor into the socket while the generator is running and spin the motor by hand. The hand-spun motor will push some electric current back into the generator and magnetize it enough to start it.
Look in the manual. There is likely something about field flashing the magnetic field2.gif. The easiest way to do this is to.
Nov 16, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
No voltage output
Nov 02, 2009 | Coleman Powermate Premium Plus 6250W...
Generator runs but can't reset circuit breaker
It probably isn't the circuit breaker. The magnetic field has likely weakened (especially if the generator has not been used in a while). The magnet can be "flashed" by running a current through the generator briefly. The easiest way to do this is to plug in a motor and spin it backwards (by hand) while the generator is running (e.g. an electric drill). The drill acts as a weak generator when you put the energy into it by spinning it.
A previous answer I gave to the same problem...
5) If the drill does not start, spin the drill's chuck in reverse [clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself].
Oct 27, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
691 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
